displaying posts 26 to 50 of 73
Pages (3): 1 [2] 3
Author Subject: Oil and Stop light on when hot but only on idle ??? SORTED
Where is the switch by the way ? Looks like its awkwardly placed right under the inlet manifold ?
Posted 9th Jun 2012 at 16:37
How many miles has the engine done?
bigbadbowen wrote:
Just seems odd that the lights come on once started to warm up and only at idle ?
Thats because the oil gets thinner as it heats up,and at idle is the slowest the crank/pump is atThumbs up
Thats the oneThumbs down
Posted 9th Jun 2012 at 16:38
Yep, depends how early or late the engine is, it screws into the front of the block and will be a grey plug connector. There are different types for early or late engines. Wink
Posted 9th Jun 2012 at 16:39
Engine done about 120k ?
Could be the oil is sh1t not sure when I last changed it ? But it's not used daily so prob only done about 3k on the oil ?
Posted 9th Jun 2012 at 16:40
Eng sound healthy?
Fingers crossed its switch!Yes
Posted 9th Jun 2012 at 16:51
darzmat
sorry to high jack, but would my 97 phase 2 have the older style oil pump thingymabobber??
i cant remember how tight i tightened my crank pully bolt Sad
Posted 9th Jun 2012 at 17:00
coskev wrote:
Eng sound healthy?
Sounds ok to me ? Nothing clonking or banging or knocking ? Oil temp has not got above 90 at any point ?
Think it's the older type plug peering into the guts it's not a new type plug No
Posted 9th Jun 2012 at 17:39
It will have the older type gear, yes. Yes
Best thing to do is to get hold of a torque wrench and just check it for piece of mind. Wink
Posted 9th Jun 2012 at 22:48
Post #35
You sorted this yet Chris? Unsure
Posted 12th Jun 2012 at 10:36
Post #36
sort of stan ? Fitted oil cooler , changed the oil and cut a bit off the crank pulley bolt changed the sensor as well but still on slightly sometimes at idle ?
Posted 12th Jun 2012 at 12:19
Post #37
Blink
Why on Earth did you do this?
Out of curiousity, what viscosity of engine oil are you running? I'm wondering if maybe it's too thin when up to temp. Dunno
Posted 12th Jun 2012 at 12:33
Post #38
stan_306gti6 wrote:
Blink
Running a billet pulley and it's different to a standard pulley has a shallower centre so just making sure the bolt is not bottimg out ?
Running 10w 40 semi synth ?
As standard ?
Changed plugs as well
Posted 12th Jun 2012 at 17:56
Post #39
Ok, I'm running an aftermarket Rich_W pulley, but not needed to cut the bolt down, but hey ho. Wink
The oil as you say is correct, so it can't be that. The worrying thing is you have changed the switch and if it's still doing it then the switch can't be faulty meaning there IS a mechanical issue somewhere. The switch pressure is set so low that it only comes on when you literally have zero oil pressure, so to have it flickering at idle is definitely not good Chris.
I'm thinking maybe the pump is starting to fail, and it's only producing reasonable pressure once it's revving. Maybe the pump gears are worn? It would be worth getting an oil pressure check done, whereby you plumb in a temporary gauge just under the bonnet and start it up and rev it etc and see what readings you get, my guess is they will be low and the pump will need looking at. Yes
Stan.
Posted 12th Jun 2012 at 20:47
Post #40
Well Stan that ain't going t happen before the weekend and I'm on the track at the weekend so see what happens ?
Didn't have this problem before I had the engine out or the dash forward ? Only thing I have changed is the pulley, engine mounts, heater matrix, oil cooler, service, front end susp rebuild, quick shift, strut brace and coolant change ?
Posted 12th Jun 2012 at 21:02
Post #41
you forgotten the big washer?
Posted 12th Jun 2012 at 21:07
ryangti6
Post #42
That could be an expensive way to find out...
Have you unplugged the oil pressure sensor when the light is flickering to check it is definitly that sensor that is bringing the stop light on?
Ryan
Posted 12th Jun 2012 at 21:16
heidi6
Post #43
This is normally a sign of engine wear in the bearings/pump especially as you have changed oil/sensors etc.
Putting an oil cooler on will cause a small drop in pressure due to the extra work for the pump but shouldn't bring on the low pressure switch. What is the low pressure rating on the switches for these engines, 1bar?, 1/2bar?
Get a pressure check done for piece of mind.
I live work (to pay) for the 306
Phase 3 Astor. Built on Wednesday, 12th April 2000 in France.
Years of 'Creative Maintenance' mean this car is now much lighter and slightly more 'race' specced... Tee hee
Posted 12th Jun 2012 at 21:19
Post #44
That's possible...
Posted 12th Jun 2012 at 21:20
Post #45
To be fair Chris, with an issue like that I wouldn't be risking going on a fast road drive let alone a track...
There is obviously something wrong, and as Ryan says a trackday could prove a very expensive way of finding out what was wrong. Yes
Heidi6 - The oil pressure sensor is set at 0.5 bar I believe. Yes
Posted 12th Jun 2012 at 21:22
Post #46
Nope it's deff there
Posted 12th Jun 2012 at 21:25
Post #47
Will be taking it out for another spirited drive before the track ? If it goes bang it goes bang ? It's not hard to find and install an engine ? Especially for me ?
Posted 12th Jun 2012 at 21:27
Post #48
naah, its 1 bar Stan Smile
Post #49
Was doing it before oil cooler went on but after the pulley change ?
Posted 12th Jun 2012 at 21:28
heidi6
Post #50
Agree with the above. Having lost a few big ends on track its not fun, or cheap.
Stan - cheers.
Pages (3): 1 [2] 3
