Author Subject: ARB end plates and boot liner
monkeyman
I need a L/H, passenger side rear ARB end plate, but just in case you can fit the ARB either way I'll probably need both sides. Ill check if its the 30 or 32 spline when I can.
Good condition rear boot liner and sound proofing mat mat needed as Ive got oil on mine. Clean, no rips or oil spills, I guess postage will be a bit with the weight but can pick up if not too far away, or at Ace meet.
I may not be able to reply until after the weekend
Forum Search Clicky
Posted 7th Jun 2012 at 11:25
jord294
i've got a pair of freshly powdercoated end caps
attatched to a hybrid arb if your interested
Posted 7th Jun 2012 at 16:09
alastairh
I should have a pair of end plates. £15 posted
Al
205 GTI6
Primera GT
Xsara VTS
306 GTI6
Posted 7th Jun 2012 at 16:35
Niall
I've got a boot carpet I can sell. Haven't got the sound deadening seeing as it always falls apart when you take it out.
I've used cloud 9 carpet underlay and that's made a really good difference to road noise! Highly recommend it and you can pick up a metre for about 10 delivered.
Posted 7th Jun 2012 at 17:28
