Author Subject: No spark or injector pulse
samuel
I've been having a lot of trouble from my gti 6 lately,
The ECU stopped working so i ordered one from RichW; put it in and it worked fine for 20 min. before it stopped!
Now we can't get it to start, there's no signal to the spark plugs or the injectors.
do you have any idea what could be going on ?
We put in 20 L of fuel, locked and unlocked the car etc. Everything else is working alright Dunno
Anyone have any ideas ?
thanks !
samuel
samuel
Posted 6th Jun 2012 at 06:23
Crank sensor sounds like it could be faulty. Yes
Posted 6th Jun 2012 at 06:59
Does the fuel pump still prime when the ignition is turned on? Unsure
Posted 6th Jun 2012 at 07:00
peetypug
Imobiliser issue??
Mine was fine one moment, pulled up to put fuel in and it wouldn't restart.
Turned out the ecu was Fooked and kept locking ecus
Solved it with another ecu and removing the immobiliser
Cherry rallye - DOB Thursday 29/04/1999
Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
roland rat wrote:
You sir either live for the 6 or have a mental retardation to still be repairing this!
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
Posted 6th Jun 2012 at 07:52
samuel
haven't checked yet, but i will do that tomorrow.
But yes, theres no pulse either the sparks or the fuel injectors. aiaiaiaiai!!Crazy
samuel
Posted 6th Jun 2012 at 08:06
samuel
peetypug wrote:
Imobiliser issue??
Alright, well if nothing else works i'll try doing this. I hope my beast gets fixed once and for all !
samuel
Posted 6th Jun 2012 at 08:08
samuel
If it does, what will it mean ?
thanks stan !
samuel
Posted 6th Jun 2012 at 09:27
If the fuel pump is priming with the ignition on, then the ECU is supplying it with a signal and it's not an immobiliser fault.
  • Posted 6th Jun 2012 at 09:34
    rich_w
    Wrong - the immobiliser does not cut the fuel pump - it cuts the injector and coil pack driver output Smile
    Contact Details:
    07732 822546
    Posted 6th Jun 2012 at 10:01
    rich_w
    thanks !
    samuel
    Samuel,
    What was the reason for failure of your old ECU?
    The ECU I supplied has been professionally unlocked and de-immobilised, in cannot lock again. Ever.
    Depending on the reason for your old ECU failing, it could be an electrical fault that's causing ECU damage and failure, it could be the crank / cam sensor, or it could be the multi-fucntion relay behind the battery box.
    Did you want to send the ECU back to me? I can test it.
    Regards,
    Contact Details:
    07732 822546
    Posted 6th Jun 2012 at 10:06
    Fair one. That correction actually makes sense in relation to an issue I had. I 'unlocked' two ECU's from breakers and kept them spare for my 205 GTi6 conversion. When I fitted one and tried to get it started I had no luck at all. I removed the fuel hose and was getting fuel, but wouldn't start. I tried the second ECU - fired straight up.
    I can only assume I must have failed to remove it correctly to unlock it as with another ECU it all started up fine so it must be a fault with the ECU alone. Do you still buy locked ones Rich?
  • Posted 6th Jun 2012 at 10:16
    rich_w
    Yeah, that all sounds about right.
    Yes, I do - you want to sell me some?
    Smile
    Contact Details:
    07732 822546
    Posted 6th Jun 2012 at 10:17
    martinh
    How much would you buy a locked ecu for Rich?
    Posted 6th Jun 2012 at 19:11
    samuel
    thanks !
    samuel
    Samuel,
    Regards,
    Alright, i've just spoken to my mechanic, he's going to check the relay and make sure that's working; the crank sensor was changed yesterday so thats fine.
    Also, i noticed when i got the ecu that it was a rallye one ? that won't make a difference will it ?Dunno since I've got the gti6 ? also, the mechanic is wondering how you managed to unlock it because it doesn't seem to have been opened lol
    thanks again for your help Smile
    samuel
    Posted 7th Jun 2012 at 00:44
    A Rallye and GTi-6 ECU is the same so there will not be any difference. Wink
    As for opening it, I guess Rich made a professional job of the unlocking and it still looks original.
    Posted 7th Jun 2012 at 09:40
    samuel
    Yea thats what I assumed!
    He must have done it well cos the mechanic couldn't figure out how he'd done it Razz
    I guess here in australia they only really know their big V8s haha
    samuel
    Posted 7th Jun 2012 at 11:07
    Have you tried ringing the two guys off that advert for advice?
    They should be able to guide you through it.
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 14th Aug 2012 at 13:00
    did you sort this? if so what was it? update thread please so everyone's not wondering where you went!
    Posted 14th Aug 2012 at 13:44
    http://www.306gti6.com/forum/showthread.php?id=150129
    Posted 14th Aug 2012 at 13:55
    didn't answer what it was though LOL he said he put a RichW ecu in and it didn't fix it... so i'm curious
    Posted 14th Aug 2012 at 13:58
    Agree with Rikky, would be interested to know what the cause was. Yes
    Posted 15th Aug 2012 at 09:27
