Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS
| Author | Subject: aux belt pulleys qty ? |
skybluken
Junior User Location: bristol Registered: 16 Jan 2012 Posts: 100 Status: Offline |
i have a ph1 no a/c and trying to fit a 6pk1160 belt TO LONG!!. I have 4 pulleys? (PAS pump,crank,tensioner and alternator) the tensioner is manual at the top behind pas pump, all pictures i have found seem to show one at the bottom aswell? between crank and alternator below tensioner do i need this or can i just mis this out and put a shorter belt on. Car was originally throwing belts then i discovered i had no spacers on pas pump so was out so now have spare one lol.________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
stan_306gti6
1163mm is the correct length of the belt you need for that setup. ![]() I believe you should only have 4 pulleys for it to travel round... ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
skybluken
i must be gettin the route wrong cos its to long anyone got a picture or draw one to show how it should fit please ________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
ryangti6
Seasoned Pro Location: Pontypool Registered: 01 Sep 2006 Posts: 1,839 Status: Offline |
![]() This is how it should be ________________________________________ Ryan |
stan_306gti6
There is a bolt missing out of that tensioner Ryan...________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
ryangti6
Well done for pointing out the obvious Stan ![]() I think that picture is still of more use than telling the guy he should only have 4 pullies when clearly he should have 5... ________________________________________ Ryan |
skybluken
cheers ryangti6.guess i got to source a replacement pulley?________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
stan_306gti6
ryangti6 wrote: Well done for pointing out the obvious Stan ![]() I was pointing it out in case the OP did not notice and was unsure why his setup looked different to the one pictured when he went back to have another go at fitting...no need for the attitude. ![]() ryangti6 wrote: I think that picture is still of more use than telling the guy he should only have 4 pullies when clearly he should have 5... Yes, that picture is extremely helpful, well done for posting it up. I obviously made a mistake when I was trying to picture the setup in my head, again a simple mistake no need to cause an issue. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mechanical_repairs
stan_306gti6 wrote: ryangti6 wrote: Well done for pointing out the obvious Stan ![]() I was pointing it out in case the OP did not notice and was unsure why his setup looked different to the one pictured when he went back to have another go at fitting...no need for the attitude. ![]() ryangti6 wrote: I think that picture is still of more use than telling the guy he should only have 4 pullies when clearly he should have 5... Yes, that picture is extremely helpful, well done for posting it up. I obviously made a mistake when I was trying to picture the setup in my head, again a simple mistake no need to cause an issue. ![]() Ha ha told you Stan you thicko. Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
stan_306gti6
@ Carl!________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
ryangti6
Well perhaps if it wasn't aimed at me, didn't have the ... you seem to post after everything and in general didn't post a lot of comments stating the obvious, I wouldn't of said anything. Nothing in my post was offensive so you can save the lecture on the attitude thanks. ________________________________________ Ryan |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
:popcornsmiley |
stan_306gti6 wrote: 1163mm is the correct length of the belt you need for that setup Ah bugger, I have one from GSF which says "6PK 1155" - does that mean they've given me the wrong one? I'm also P1 without air con. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
skybluken
owain wrote: stan_306gti6 wrote: 1163mm is the correct length of the belt you need for that setup Ah bugger, I have one from GSF which says "6PK 1155" - does that mean they've given me the wrong one? I'm also P1 without air con. Guees so, Peugeot told me it was 6 rib 1160 then wanted £18+ vat, GSF i went lol. Now i need a pulley cos thats to long :-( more ruddy money ________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
Annoying, guess I'm off to GSF today then. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
skybluken
Had to have a 6pk 1165 as they didnt have a 1160 cost me £10. Then got home to fit the pas pump as had to get new spacers and bolts(£17 @ peugeot :-() as the twat who put the replacement engine in didnt know hs bolts from his nuts. Then discovered belt to long because i got a pulley missing aswell :@________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
owain wrote: stan_306gti6 wrote: 1163mm is the correct length of the belt you need for that setup Ah bugger, I have one from GSF which says "6PK 1155" - does that mean they've given me the wrong one? I'm also P1 without air con. I'd hold fire before you start worrying. Stan isn't on top form today so I would take his length with a pinch of salt. ![]() ________________________________________ ![]() |
stan_306gti6
1163mm it is. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
allesclar
Seasoned Pro Location: Sheffield Registered: 17 May 2009 Posts: 4,254 Status: Offline |
just a quick one, how does one get the two middle pulleys off? i cant see the bolt in the picture.________________________________________ Team allesclar ® |
skybluken
The tensioner has 2 bolts the bottom one it pivots on and the top one is the locking one. The idle pulley just has 2 bolts one top and one bottom these are lots of fun as hard to get at but all are 13mm, remove wheel and inned trim to get at bottom bolt, have fun________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
