Author Subject: PTFE gasket fitting
darrengti
Hi all
After showing an interest in the above Mrswampy PM'd right away offering longer bolts to assist with fitting. My question, are longer bolts necessary? What have others done?
Thanks
Posted 2nd Jun 2012 at 09:49
mr swampy s16
**BAD SELLER**
Some people use some don't
Peugeot use a bony as standerd that is adequate for the job, the standerd gasket is like1.5mm thick
So fitting a thicker gasket means less of the thread is in the head, so less thread is gripping and securing the manifold
You need to be able to tighten it down correctly to ensure a good seal as an air leak at the manifold causes all sorts of running issues
Posted 2nd Jun 2012 at 10:59
Rich E Forum Admin
Not required, the standard bolts are absolutely fine.
As for tightening down the inlet, the correct torque load is only 20Nm.
Posted 2nd Jun 2012 at 11:20
darrengti
Thanks Rich. What does 20Nm feel like on the internal torque wrench?!
Posted 2nd Jun 2012 at 17:09
Not very tight, it's less than what you would tighten spark plugs to (25Nm). Wink
Posted 2nd Jun 2012 at 17:14
darrengti
That's good to know. I would have charged in like a bull in a china shop!
Posted 2nd Jun 2012 at 17:18
woody.
Poor swampy!
Posted 3rd Jun 2012 at 01:54
chris with a pug
Just don't use anything on the faces of it like a sealing paste as it will deform with the heat. Happened to a member on here.
Posted 3rd Jun 2012 at 10:18
^^What he said, they don't need anything on the sealing faces, it won't bond to the ptfe and just stops the faces gripping and the gasket squeezes out. Pay attention to the torque too as overtoquing dooesn't do them any favours. If you have one of the black carbon/mica reinforced ones they're a bit more tolerant of abuse though.
Posted 3rd Jun 2012 at 10:30
