Author Subject: Axle mounted compensator
jord294
Now this is a strange one. Even I don't understand Huh?
I was always led to believe all gti6 and rallyes had brake compensators fitted to rear axle.
But lately I have found that although even some hdis do aswell, not all gti6s do.
Anyone care to explain why?
As now, if anyone wants a beam off me, I have to ask if their car has a compensator or not, so I can supply the right ' hangers'
Posted 30th May 2012 at 19:25
Rich E Forum Admin
They are not fitted to any phase 3 cars as the ABS unit is updated to provide electronic brakeforce distribution (EBD).
Posted 30th May 2012 at 19:30
Phase 1 and 2 have compensators, Phase 3's do not as they are fitted with EBD and the limiting of brake fluid to the rear is done via the ABS pump. Yes
Posted 30th May 2012 at 19:32
jord294
but i've had customers with 2000 cars with a compensator Hmmm
when did phase 3 officially kick in
thanks in advance Thumbs up
Posted 30th May 2012 at 19:35
Late 1999, but it could be that you had a 2000 registered car which was actually built early 99...
Posted 30th May 2012 at 19:38
jord294
thanks guys
should make supplying rebuilt axles a bit easier Wink
Posted 30th May 2012 at 19:39
No problem. Thumbs up
Just make sure you ask the question then you'll be good to go.
Posted 30th May 2012 at 19:41
