Author Subject: good radiators
chris1987
Hi guys and girls any one no of a good brand of radiator to get for the 6 ?
Posted 29th May 2012 at 11:00
Nissens are a resepected brand of Aluminium units.
  • Posted 29th May 2012 at 11:10
    milkyb
    i've got a nissens and my car has touch wood never overheated since, infact, my water temp is regualarly below the half way mark. fantastic rad
    Posted 29th May 2012 at 11:33
    rallyecomms
    i got a Nissens aluminium one the other week, and so far so good. very solid bit of kit in comparison to an OEM once i'd ordered previously.
    Road Rally car - Manstone Ph3 GTI-6. Quaife ATB, hydraulic handbrake, OMP Cage and loads of other rally crap!
    Rally Car - Ford Olympic Blue!. Quaife ATB, hydraulic handbrake, Safety devices cage, GpN Pug Sport kit!
    Posted 29th May 2012 at 11:41
    Nissens all the way, brilliant pieces of kit.
    I have one on my car and it's a fantastic rad. Yes
    Posted 29th May 2012 at 11:48
    chris1987
    Thanks for the info guys So Im Guessing Nissens is a good brand then. Are there a simple plug in and play using the old pipe work radiator or will I need some sort of kit ?
    Posted 29th May 2012 at 12:28
    lewisdmz
    Good to see another SW member, you will need to double check you have the correct bottom hose as per this FAQ
    http://www.306gti6.com/forum/showthread.php?id=50379
    Posted 29th May 2012 at 12:37
    Yes, as long as you have the later style bottom hose with the metal spring clip it will fit straight on.
    If you don't have it, the pipe itself is only around £20 from Pug and easy to change. Yes
    Posted 29th May 2012 at 13:00
    chris1987
    I need to get a new bottom hose anyway as I have post before .I think this radiator is what iv bin looking for thanks for you help with this as I was not 100% on the brands out there . Ps nice to meet a sw member as well. If you fance a read (www.306gti6.com/forum/showthread.php?id=148009)
    Posted 29th May 2012 at 16:02
