Author Subject: turning over but no spark and injectors not opening
dannygti-6
Transferd one rolled rally in to the famous pug plus shell all together but won't fire got a feeling its the immobliser but changed the Ecu and key arial from the other car is there any other boxes on these that are coaded to the key ?
Xbox Live = Sp4n
Team one gti-6 - 2 cherry rallye's
Posted 25th May 2012 at 18:16
There's an immobiliser box under the centre console ash tray bit I think.
  • Posted 25th May 2012 at 18:21
    simonjames
    Yes as above
    Does your fuel pump come on when ignition switched on?
    have you checked fuel shut off ?
    MY EBAY ITEMS
    07943066306
    Posted 25th May 2012 at 19:09
    Fuel relay. Is it a known working one you are using?
  • Posted 25th May 2012 at 19:11
    Its controlled by the immobiliser box though so it sounds like that is the issue.
    Posted 25th May 2012 at 19:22
    pete_rallye
    Have you checked the inertia switch? The big red button on the passenger side that trips out if you have a shunt, it's like an automatic fuel shut off. I'm not sure it would cut the spark too mind, but worth a try. You can check it by linking it out, but just try pressing it first...
    Lap of the 'ring
    Posted 25th May 2012 at 22:44
    Doubt that's the problem Pete ? Sounds like he has forgotten to move over the immobiliser box from under the dash Yes
    Posted 25th May 2012 at 22:47
    This ^^
    Posted 26th May 2012 at 01:40
    dannygti-6
    Yep missed the immobilizer box ! All running now
    Thanks Dan
    Xbox Live = Sp4n
    Posted 26th May 2012 at 08:49
    Thumbs up
    Glad you got it sorted mate. Smile
    Posted 26th May 2012 at 09:00
