Author Subject: All sidelights not working
Alrite chaps,
It seems that none of my sidelights are working, and same story with the rear number plate lights.
Checked fuses and replaced with known working ones to no avail. Tried swapping lights over from my other car to no avail.
Any ideas?
Posted 25th May 2012 at 16:56
Knackered stalk?
Posted 25th May 2012 at 17:51
Do the instrument lights illuminate?
Stalk is a good shout. I have one somewhere.
  • Posted 25th May 2012 at 18:16
    I thought the stalk too, but when I turn it, dash illuminates so guessed it wasnt the stalk that was the issue as it recognised I had turned it?
    Posted 25th May 2012 at 20:20
    Not necessarily, it could be a double-pole switch, so it actually has two separate electrical switches inside the one mechanical unit.
    I don't know if that's the case, but that's how it works if you want to have one switch control two things on different fuses or relays.
    Posted 26th May 2012 at 09:19
    Will try get another stalk as these still arent working. Lucky for me, days are longer at the minute and not used the car at night.
    Posted 7th Jun 2012 at 11:14
    306xsi
    Having the same problem, did you manage to solve this?
    Posted 29th Mar 2014 at 19:16
    jimmyhackers
    is the earth still connected on your rear passenger tail light?
    sounds like it might of gone bad.
    Posted 1st Apr 2014 at 18:04
    306xsi
    Managed to get mine working in the end so thought i would post up my solution.
    I had recently changed the heater matrix so was pretty sure it was a loose connection somewhere. It turned out to be the main loom connection between behind the dash and the engine bay (found under neath the windscreen wiper motor). I basically just unplugged it and plugged it back in again and it worked.
    Hopefully this helps out someone in the future!
    Posted 23rd Apr 2014 at 00:19
