My driver side window falls down. So if I put it down the front that is closest to the wing mirror falls down - does anyone know what it could be?
Phase 1 silver track car335i daily
| Author | Subject: Window falls down - whats wrong? |
sergioiacobucci
Senior User Location: High Wycombe Registered: 27 Nov 2007 Posts: 526 Status: Offline |
Hi,My driver side window falls down. So if I put it down the front that is closest to the wing mirror falls down - does anyone know what it could be? Cheers ![]() ________________________________________ Phase 1 silver track car335i daily |
6waysforward
Seasoned Pro Location: Benfleet essex Registered: 30 Oct 2005 Posts: 3,168 Status: Offline |
The window has come out of the runners by the sounds of it prob due to a knackered clip or the runner at the front has come away.________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
sergioiacobucci
6waysforward wrote: The window has come out of the runners by the sounds of it prob due to a knackered clip or the runner at the front has come away. Ok cool take the door card off and have a look? Or will it be covered so i cannot see it? Thanks for the pointers ________________________________________ Phase 1 silver track car335i daily |
pebbles167
Seasoned Pro Location: Melksham. Wiltshire. Registered: 08 Dec 2009 Posts: 2,516 Status: Offline |
Take the door card off and peel back the foam, power down the window until you can access the window + clip and inspect.Post up here when you can see what's wrong and ill take you from there. ________________________________________ 2005 Peugeot 206 GTI 1802008 BMW K1200R |
sergioiacobucci
pebbles167 wrote: Take the door card off and peel back the foam, power down the window until you can access the window + clip and inspect. Post up here when you can see what's wrong and ill take you from there. Great thanks will do that tomorrow morning and post it upcheers for the help guys ________________________________________ Phase 1 silver track car335i daily |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
Be careful if you're buying a second hand motor unit, they fit different in phase 1's than phase 2/3's. I had to chop some bolts up to fit them and they use a different rubber part to hold the window on the main slider.It sounds like the clip on the side of the window nearest the B-pillar has broken. These can be had from pug for a quid or two. This job really got on my tits when my drivers side one went bad. Thinking back it's so easy to fix, just had the wrong parts! Good luck |
webster
Seasoned Pro Location: Colchester Registered: 20 May 2007 Posts: 2,059 Status: Offline |
The job is a pain in the ass and fiddly so take your time and be ready to become frustrated ![]() ________________________________________ cress87 wrote: I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past. |
The clip will undoubtedley let go again (I had a garage refit the window twice for it to fail again within a few weeks), I lubed the runners with silicone grease and then used a dremmel to key up the surface of the glass on both sides in the area the clip fits onto the window, I then put epoxy resin on the glass and the clip and left the two to cure for half an hour before refitting. It never came off again after that.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
willow
Regular Location: horley Registered: 21 Jun 2004 Posts: 123 Status: Offline |
Yes, as above a few years ago my wife's dturbo had this problem, tried several clips and I ended up changing the whole window regulator mechanism. It just popped out again. Turns out all it needed was a good spray of silicone around the seals and it was fine after that. |
ardandy
Seasoned Pro Location: Keighley Registered: 03 Feb 2005 Posts: 6,053 Status: Offline |
sergioiacobucci wrote: Window falls down - whats wrong? It should be up? |
