Conrod Bearing Set 6B1490
Oversize STD, .25, .50, .75, 1.00
Brand ACL Duraglide
Manufacturer ACL
Conrod Bearing © 1490
Half Type Identical Halves
Manufacturer ACL
Min Std Shaft Size 1.7707in / 44.975mm
Max Std Shaft Size 1.7713in / 44.991mm
Min Std Tunnel Size 1.8898in / 48mm
Max Std Tunnel Size 1.8904in / 48.016mm
Max Wall At Crown 0.0588in / 1.493mm
Max Overall Length 0.7087in / 18mm
Min Vertical Oil Clearance 0.0009in / 0.023mm
Max Vertical Oil Clearance 0.0032in / 0.081mm
Material F780
and these-
Conrod Bearing Set 6B1490H
Oversize Std, .025, .25, .50
Brand ACL Race Series
Manufacturer ACL
Conrod Bearing © 1490H
Half Type Identical halves
Manufacturer ACL
Max Wall At Crown 0.0587in / 1.49mm
Min Vertical Oil Clearance 0.0011in / 0.029mm
Max Vertical Oil Clearance 0.003in / 0.077mm
Material F781
There for a steel crank with 45mm big ends, hence they are BMW bearings, not Peugeot. The bit I need confirmation of is the 'Max Wall at Crown', is that the bearing thickness? And also the Min and Max 'Vertical oil clearance' I take it this is the clearance between the bearing inner face and the crank journal? And you'd measure that with Plastiguage?
The bearings that came out of it are the top 1490's, but I'm tempted to use the race one's, purely because there called race bearings and will cost me more.
Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2
Lap of the 'ring
