displaying posts 26 to 40 of 40
Pages (2): 1 [2]
Author Subject: 30k HID's not to everyone's tastes I know,..
4200 or 4300 is the best to get and what you'll find as o.e, 12k is massively lower light output its unreal
12k did a damn fine job of lighting everything up!
i'll take a pic with the 30000's on and how well they light if the iphone can interpenetrate what I see,..
does the job looks different doesn't blind I'm happy anyway! i promise that if I get pulled or flashed at for p**sing someone off then i'll take them out Smile and just use them for pix etc Smile
Posted 23rd May 2012 at 21:34
mattgti6phase2
I have run 8k and 10k from what i have read the higher the K the lower the lumens which from what I understand doesn't throw the beam as far Dunno
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 24th May 2012 at 12:41
owain wrote:
The MOT Tester's manual for 2012 says this:
quote:
Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted
with headlamp washers and a suspension or headlamp self levelling system.
Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given.
So there's no specific exceptions, it's simply a best effort. However if you dazzle a copper, you'll get a fine.
It's in one of the amendment notices somewhere.
Posted 24th May 2012 at 15:17
As promised the lights
They light up the roads fine enough for me
Posted 25th May 2012 at 01:25
Laugh my ass off
Posted 25th May 2012 at 08:58
Laugh at that pic
i had 4300k and found them to be the best 'standard' looking xenons. i'm going to try a set in the 406 v6 as it's got proper projector lights and headlight washers so i think they'll work well
Posted 25th May 2012 at 09:12
jonnyvandijk
I had 6000k for a few years, but was so paranoid I was blinding people (which I was, all the aftermarket kits leak light no matter what anyone says) so they are now in a box in the garage. Trouble is I am now blinded by everyone else Sad
You can see clearly there is light leakage on the above pic, there is no sharp horizontal line where the light stops. Just a nice purple blur LOL
Black 306 GTi-6 Ninja 175.8BHP SCA Norwich Project
Topaz Blue 205 CTI Happy
Posted 25th May 2012 at 09:38
that's because the gti6 lights don't have projectors. i've been dismantling various 406 lights over the past week or so and the projectors in them are removable, i wondered how they'd look putting them into gti6 headlights because then when running the HID's you'd get no glare and a crisp line
Posted 25th May 2012 at 09:46
that's only on Dipped isn't it Rikky? main beam is an un-shrouded H7 same as a gti6 lamp.
Posted 25th May 2012 at 09:55
Post #35
http://www.ebay.co.uk/itm/251004054629?
sidelights are as normal and the projector is for the dipped beam which gives a better light pattern i've found Yes the main beam i have no idea, it'll just be another bulb like the gti6
Posted 25th May 2012 at 10:24
Post #36
could the actually be done then do you recon?
mite be worth a punt Dunno
get some pix up of the bits you recon can be swapped
Edit:
just found one cheap enough to have a look at,...
I suppose I could look into this at the very worst it'll go in the bin
or could try Black Mask it Smile
Posted 25th May 2012 at 12:33
pugbug
Post #37
I've got 5000K HID's in P2/P3 Angel eye projector lamps, they're the best compromise and look ace!
Posted 25th May 2012 at 12:53
Post #38
Edit:
that's why i took mine apart, to black mask them Yes
Posted 25th May 2012 at 12:54
Post #39
the after market 306 Projector lights don't have auto adjusters do they?
Posted 25th May 2012 at 12:55
Post #40
Cool how'd they look?
Posted 25th May 2012 at 13:01
Pages (2): 1 [2]
