just to confuse me more it is a nearly new delph calliper new discs and pads with dowel on one to locate in in the groove on piston have I done something stupid or missed something Cheers lads
| Author | Subject: No handbrake application ???????? |
Moonstone6
Regular Location: Lichfield Registered: 11 Apr 2012 Posts: 268 Status: Offline |
Hi all my the gti6 I recently brought has had a s**te handbreak so I looked at callipers and noticed one of them does not bite the disc when the lever is pulled the cable is still in one piece and the arm on calliper moves when handbrake pulled but the piston does not move just to confuse me more it is a nearly new delph calliper new discs and pads with dowel on one to locate in in the groove on piston have I done something stupid or missed something Cheers lads |
are they seized? sliders etc?did you stomp the pedal with wheels on the ground before fittng handbrake cable? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Moonstone6
welshpug! wrote: No mate it slides back n forth as it should my only thinkin is the callipers fooked are they seized? sliders etc? did you stomp the pedal with wheels on the ground before fittng handbrake cable? |
did you do the second bit mentioned?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
I reckon it needs bleeding properly ? |
Moonstone6
bigbadbowen wrote: I even bled it aswell to cancel that scenario and still the same mateI reckon it needs bleeding properly ? |
Moonstone6
welshpug! wrote: Never noticed the 2nd bit you put I wound calliper back with handbrake released but cable connected the arm On calliper was in the released position I then pumped the pedal then applied the handbreak to check I think the calliper is faulty its sealed on the back clean grease n rubber boot is perfect did you do the second bit mentioned? |
Does it have a new cable ? Sounds like the cable is not tensioned correctly ? If it's had a new cable it could be the wrong side ? Ie left on right or vise verser ? One is slightly longer than the other |
Moonstone6
bigbadbowen wrote: Oo I never knew that about the cables being diffo lengths well I'm gonna get it on the ramp in the week so il av a better look at it then il strip calliper aswell to have a butchers thanks dude Does it have a new cable ? Sounds like the cable is not tensioned correctly ? If it's had a new cable it could be the wrong side ? Ie left on right or vise verser ? One is slightly longer than the other |
cress87
Seasoned Pro Location: Norwich Registered: 30 Mar 2007 Posts: 11,360 Status: Offline |
But you said the lever on the caliper moves when you apply the handbrake so it can't be a cable issue. ________________________________________ ![]() You feed beefburgers to swans. ![]() I may have been speeding Mr Policeman but [a] I live for the 306 and [b] did you see that dog? omfg |
Moonstone6
cress87 wrote: Well that's what I though mate I thought you just adjust the small cable on the lever and the two cables are fixed length I checked the other calliper for comparison n the levers for handbrake cable are in identical positions when h brake applied n released its gotta be a fault within the calliper I'd have a look on my break at work but I'm too busy But you said the lever on the caliper moves when you apply the handbrake so it can't be a cable issue. Tonite |
stan_306gti6
From what you've said, I'd be inclined to agree that the caliper is where the fault lies.If the wheel is off the floor and you turn it by hand, get a mate to press the brake pedal and see if it stops you being able to turn the wheel. That will tell you if the caliper is working at all. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
if you don't press the pedal several times with the wheels on the ground (or the compensator valve held open) the piston wont self adjust, fitting the cable before doing this seems to prevent it from doing so fully.also pressing the pedal with the wheel off the floor with a load compensator doesn't always work ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cress87 wrote: But you said the lever on the caliper moves when you apply the handbrake so it can't be a cable issue. Doesn't mean its moving far enough though Lever the handbrake arm on the caliper with a screwdriver,and see if you can turn the wheel then I had a caliper that was like this on my 309,lever moved fully on but did nothing to the piston ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Moonstone6
stan_306gti6 wrote: Hi mate yea the calliper works fine hydraulically just not mechanically the disc was new last month and had even wear to the other one From what you've said, I'd be inclined to agree that the caliper is where the fault lies. If the wheel is off the floor and you turn it by hand, get a mate to press the brake pedal and see if it stops you being able to turn the wheel. That will tell you if the caliper is working at all. Gotta. Be the calliper |
stan_306gti6
As Coskev says try to manually pull the handbrake lever on the caliper on with a screwdriver and see if the wheel locks up. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Moonstone6
stan_306gti6 wrote: Yep it's the only thing for it ent it lads thanks for your input fellas As Coskev says try to manually pull the handbrake lever on the caliper on with a screwdriver and see if the wheel locks up. ![]() |
ian7675
Techno Viking Location: Gloucestershire Registered: 12 Oct 2007 Posts: 6,068 Status: Offline |
How many clicks on the handbrake lever have you adjusted it to? ________________________________________ Less than 24 hours to go! |
stan_306gti6
ian7675 wrote: How many clicks on the handbrake lever have you adjusted it to? An acceptable tolerance is between 4 and 7 clicks by the way... Seeing as the handbrakes aren't the best on the disc beam I usually set mine to 4. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
ian7675
stan_306gti6 wrote: ian7675 wrote: How many clicks on the handbrake lever have you adjusted it to? An acceptable tolerance is between 4 and 7 clicks by the way... Seeing as the handbrakes aren't the best on the disc beam I usually set mine to 4. ![]() I know Stan, I did 4 too. I was asking the OP to check the cable isn't too slack on the lever ________________________________________ Less than 24 hours to go! |
