displaying posts 1 to 25 of 33
Author Subject: idling issue...
Teshboi1988
did a full conversion from 1.6 5door 306 to the gti
everything been swapped
she runs
but she idling at 3,000
replaced idle control valve o e quality
but stays at high revs all the time...
adjusted accelerator cable + the lil adjuster on the throttle body..
but nothing
at first it was idling high then the rev counter stopped working.... replaced fuel pump relay and got rev counter working...
now just stuck on this issue... would a remap sort it?
phase 3 Hatchback V reg 5Door GTi6
Posted 10th May 2012 at 19:45
Sounds like you've got an air leak. Yes
Posted 11th May 2012 at 01:18
Teshboi1988
any common places?
Posted 11th May 2012 at 07:48
Inlet manifold, where it joins the cylinder head is a common one. Make sure the bolts are all done up even and tight.
What's the state of play with this engine now, have you swapped the engine for a standard one, rather than the one with aftermarket pistons?
Posted 11th May 2012 at 10:18
Teshboi1988
yea took your advice bought new engine running order. bt he said it had been sitting for a while.....
bt yea put it all together started fine took it for a drive next day she started idling high 3,000rpm when you drive it drives ok nt pulling hard bt revs bounce up wen changing gear...
got a straight through system so kinda bt embarrassing sitting at traffic lights at 3,000rpm lol
so dunno.. il have to take inlet off i spose n propa clean it
anything else i should try??
i got a new cam sensor cos got told might be that so just going through process of elimination
Posted 11th May 2012 at 18:45
It won't be the cam sensor, that is only used whilst starting the engine.
You either have a dodgy ICV or an airleak. At the kind of RPM you're talking, I'm leaning towards airleak.
Posted 12th May 2012 at 01:38
swiftyboi006
Clean the icv out 1st befor removing the mani, once you have checked that then move on towards the head looking for an air leak. Check the resonator is not cracked and sealed prop. Did you remove the inlet at any point? Replace the gaskets?
Black p3 Love
Posted 12th May 2012 at 07:02
Teshboi1988
yup put new inlet gasket onit... n new o ring on resonator
it idles fine wen cold wen warmed up then theres a problem.
bt cool yea il check
icv is new thou... how is icv meant to work? valve pushes up and down or screws up n down.
Posted 12th May 2012 at 07:10
swiftyboi006
I think it pushes up and down to let in more air when needed to idle correctly, when yours heats up it may be atayin open, take it off and give it a spray up with carb cleaner
Black p3 Love
Posted 12th May 2012 at 07:41
Teshboi1988
icv when it is down isit closed or open?
Posted 12th May 2012 at 08:16
swiftyboi006
Open i think Thumbs up
Black p3 Love
Posted 12th May 2012 at 08:48
davewagon
Spray some wd40 or carb cleaner around the inlet manifoldand the gasket where it meets the engine, while the car is running.
If it stutters, then you'll have a leak (the wd40 is being sucked in and interfering with the combustion).
Be generous with it.
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 12th May 2012 at 09:06
swiftyboi006
Put some paper under the boddie if you do that as you will get alot of spray from wd40. I wouldnt use carb cleaner as its flammable Doh
Black p3 Love
Posted 12th May 2012 at 10:30
Teshboi1988
ok will try that tomorrow...
icv wen i put my thumb over pipe n let a lil air in it idles fine... if i block it completly it cuts out..
if i have a leak somewhere around intake are, and i cover throttle whole and icv would i see it suking in elsewhere or dont it work like that
so if both bits covered and it still runs iv got air leak
if it cuts out no air leak??
Posted 12th May 2012 at 16:49
This sounds correct, therefore I would imagine your ICV is in need of replacement if you can let a small amount of air in and when you let the normal amount of air in it idles too high. Yes
Posted 12th May 2012 at 16:54
Teshboi1988
yea what i thought.... but i did get new icv and put it in... bt still same. so wot this new one has fault?
so no air leak?
Posted 12th May 2012 at 19:38
Unplug the PAS sensor in the fluid line and see what happens. These have been known to cause idling issues in the past.
Failing that, your TPS could be faulty...
Posted 12th May 2012 at 22:37
Teshboi1988
will try it
so u dont think there could b a air leak
Thanks for your help stan, and others
much appreciated
Posted 13th May 2012 at 08:01
No worries mate. Thumbs up
I don't think there is an airleak as if you blocked the ICV intake pipe and it cuts out it can't be receiving air from another source. No
You definitely have an electrical issue most likely with a sensor. Yes
Posted 13th May 2012 at 09:16
and WD40 isnt?! Laugh my ass off
Posted 13th May 2012 at 09:18
Teshboi1988
kl cn u list possible sensors? and rough price if ya no.... it ran perfect first time i drove it then next day high idling..
def sensor
if i get it plugged in would it tell me which sensor?
Posted 13th May 2012 at 12:28
Teshboi1988
right i reckon it sank to do wiv idle control valve
in mrning or starting it up cold its perfect just below 1000
asoon as it warms up 3000 n stays unless in gear
blocking valve a lil me controling how much air goes in in runs sweet
took valve out twisted it a lil n blew in the hole til it was kinda hard to blow... put it bk in n boom ran perfect
i got a new idc so must the new one be faulty or is ecu telling it to open when it shudnt be.
this is sensor i got off ebay below
www.ebay.co.uk/itm/280551378825?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_1064wt_1189
Posted 14th May 2012 at 19:11
woody.
As stan the man says, have you unplugged the power steering sensor? It's between the rad and the fannymold and is normally coloured blue. Unplugging and replacing this solved my idle problem Yes
Posted 15th May 2012 at 15:17
woody.
I wouldn't be too keen on using that mate, it says it can be used on a 106 Rallye and XSi but the part numbers don't match up on service box...
Posted 15th May 2012 at 15:31
Genuine ICV should be used...Yes
I know it's more expensive but it will last longer and perform better in the long run. Smile
Posted 15th May 2012 at 16:18
