displaying posts 26 to 33 of 33
Pages (2): 1 [2]
Author Subject: idling issue...
swiftyboi006
swiftyboi006 wrote:
Put some paper under the boddie if you do that as you will get alot of spray from wd40. I wouldnt use carb cleaner as its flammable Doh
and WD40 isnt?! Laugh my ass off
Doh not thinking
Black p3 Love
Posted 16th May 2012 at 19:58
Teshboi1988
right i got icv from pugs
fitted that bit better... idling at bout 2g now... stuck a 17m bolt in the tube. and it idles perfect...
pulled out that blue powersteering sensor bt still was same
looked on auto data and second step for high idling would be some evapourotor valve? on driverside.... wood that effect it??
phase 3 Hatchback V reg 5Door GTi6
Posted 16th May 2012 at 20:40
When you fit a new ICV, you should turn the ignition on so you hear the fuel pump prime wait 5 seconds and turn it off again.
Repeat this procedure about 10 times before cranking the engine. The reason is because everytime you do it the ICV moves a little further out and initialises until you've done it a few times and it is in the right position.
I suspect you need to do this a few times to initialise it so your high idle will disappear. Smile
Posted 16th May 2012 at 21:54
Teshboi1988
u no ur s**t stan.
thnks mate il give that later thnks
Posted 17th May 2012 at 07:05
Check you have got 12v+ going to your ICV with Ign onYes
Had exactly this problem on my 309 when converted to Gti6 powerWink
Have you had to chop up and join looms etc?
If not could well be the big relay behind the battery box,as this supplies the live to the ICVThumbs up
Posted 17th May 2012 at 10:01
Teshboi1988
na nothing had to be chopped everything connected straight up...
yea fuel pump relay... got a new one for pugs along with new icv from pugs...
but yea cnt c if it idles properly yet cos taken cam boxes off (lump of metal) as oil was seeping from it n burning on manifold..
wot are torque settings? for em and the covers
10 n 15 init?
Posted 18th May 2012 at 11:07
Lose the txt talk pal,or people will not bother trying to help youNo
Check voltage at ICV when new relay fitted,if you have not got +12v with ign on ICV will not work,could be a ECU problem too.
Posted 18th May 2012 at 11:24
coskev wrote:
Lose the txt talk pal,or people will not bother trying to help you.No
+1. Thumbs up
Posted 18th May 2012 at 12:22
Pages (2): 1 [2]
