Author Subject: Another vibration thread - solved
darkgti6
Ive been getting some vibrations inbetween 65 - 80mph which seemed like unbalanced wheels and which continued as my speed increased although felt much finer with increased speed and still noticable through the steering wheel and floor pan. I thought it was my usual troublesome s**tty cyclones that were out of balance again. Anyway I finally got round to putting on a set of Pro race 1.2's yesterday with new tires all balanced and the problem is worse Unsure
Ive also been noticing a bit of a click/clunk at full lock whilst pulling away or reversing for a while now (although not all the time and only one click not repetitively) and stopped off earlier on the way home in a car park to try and instigate the noise. I was on a slope and if I applied full right lock and pulled away it was fine but if i let gravity take over and stop the car and then roll backwards it would make a click i could both hear and feel in the footwell. Not only that I had a punt down the dual carriage way and it seems like im getting a bit more vibration when im accelerating from 70mph upwards although doing it doesnt seem to be as severe each time i try it. Weird.
Now ive had recon driveshafts on the car which have done 30k now but all these symptoms (to me) are saying they are knackered?Dunno
Whats your thoughts?
Team Peugeot Sport 308 Gti�
Posted 9th May 2012 at 21:04
judge dead
seems like driveshaft or possibly a dodgey ball join/tie rod end as another suggestion to check altho i doubt it. jack both front wheels up and get someone to drive it and turn lock to lock and see if you can hear/see fault.
Posted 9th May 2012 at 21:11
darkgti6
Tie rods have been done last month. TRE's not too long ago and p bushes and front wishbone bushes are all fine. I was thinking ball joints because its felt a little vague at the front end recently but would they really cause that fine vibrations at sort of 90mph plusDunno
Posted 9th May 2012 at 21:18
darkgti6
The ball joints are from Motor Parts Direct made by First Line. Went on early last year and would have seen about 8k worth of abuse so far. The quality of them is rubbish I wont be using them again but do you think if these are fubered they would cause a vibration at speed? Would certainly explain the vague steering feel and wandering on bumpy roads.
Posted 9th May 2012 at 22:07
Your balljoints won't be helping the situation that's for sure.
However, I believe your problem could be the start of a CV joint on the driveshaft giving up the ghost.
Does your gearstick wobble at all on acceleration? Unsure
Posted 9th May 2012 at 22:50
darkgti6
Agreed, those First Line items are awful. They really dont last, I remember saying to myself last year when I put a another First Line offside one on 'never again' and its been 8k since at least so i think they will be my first job. Only reason I used them is because all the other motor factors are some distance away. Just seen ECP have finally opened up a new branch near me nowSmile
stan_306gti6 wrote:
However, I believe your problem could be the start of a CV joint on the driveshaft giving up the ghost. Does your gearstick wobble at all on acceleration? Unsure
Nope - when I pull away theres no vibration. I dont get any vibration till I hit motorway speeds. Just thinking when I floored it earlier on an upward slope to a dual carriage way, it was the only time it felt half decent. Hows my math? Upward slope and hard acceleration - weight of car sitting back, acceleration sitting weight back even further ...... taking all the stress off the ball jointsHmm maybe the 2 kilos of extra weight in the cyclone was damping down the vibrations somewhat and now ive put lighter wheels on its pronounced the effect.
Come to think about it the only time i really get a click/clunk is when I pull of my drive down a steep sharp slope onto the road with full lock on. Gotta be those balljointsUnsure
Posted 9th May 2012 at 23:17
scotzman
Top mount bearings?
Posted 9th May 2012 at 23:54
darkgti6
scotzman wrote:
Top mount bearings?
These were replaced along with the mounts for genuine replacements in 2009 and have done around 28k miles so I dont think it would be those.
Posted 10th May 2012 at 00:05
Based on that diagnosis, I would be inclined to agree with you. Yes
Posted 10th May 2012 at 07:11
jord294
I have exactly the same issue
I'll put up with it for now though, as within the next couple of weeks I'll be fitting roller bearing wishbones with new genuine part ball joints
Posted 10th May 2012 at 08:08
Could be driveshafts i'd say. Or a knacked/ovaled hub maybe?
Posted 10th May 2012 at 12:50
I would expect excessive gearstick wobble if that were the case though...Yes
Posted 10th May 2012 at 15:43
darkgti6
Yeah no vibrations at all through the gearstick. Ive inspected the hubs for ovalling the last time I did the ball joints and they seemed fine although it was only a primitive visual inspection. I shall get my digital vernier on it this time round and measure them to be sure.
Getting some new balljoints tomorrow so I will fit them shortly to see if that sorts it. God ive paid for tracking so many times in the past year its unreal. I think 3 times already this yearRoll eyes
Posted 10th May 2012 at 21:58
The slow manouvering "clunk" is lending me towards the balljoints. Yes
Posted 11th May 2012 at 10:23
Actually thats right yeah. I which case theres only really the hub to balljoint bit being ovalled or the balljoint just knackered imo...
Posted 11th May 2012 at 16:10
darkgti6
Update on this - I replaced the ball joints. Both were in a dire state which is quite lame considering the relatively low mileage. The steering actually feels great again although i need my tracking done now.... againThumbs down
but unfortunetly the vibrations remain at motorway speeds and i can still instigate the exact same noise on the slope in the car park down the road. Aiming the car up the slope full lock right, pull away slowly and letting gravity take over as the car begins to roll backward after about a quarter revolution on a wheel i get a clunk and a smaller lighter sounding clunk (not really a click).
The vibrations at motorway speeds really do feel like out of balance wheels though its weird.Unsure
Anyways im gonna get the tracking done tomorrow then swap the front and back wheels over to see if that makes it feel any different. The backs feel fine. I spose the numpty tyre fitter could have made a mistake with them.
Posted 11th May 2012 at 20:14
The 'clunk' on full lock at minimal speeds definitely points to a CV joint. Yes
Posted 12th May 2012 at 01:29
darkgti6
Finally solved this problem and turns out it was my front wishbone bushesRoll eyes
They were the black compound powerflex items. There was no major failure but what had happened was as I moved the wishbone up and down disconnected from the hub it was rotating over the polyurethene itself. The polyurethene was remaining stationary as I moved the wishbone up and down.Crazy
Ive had the normal compound on before and did somewhere like 50k miles on them without any problems and then when I did remove them they were absolutely fineDunno
The stiffer compound must just be unfit for this application. Anyway I stuck in some Motaquip VSK623 items and it feels much better and most importantly no vibrations through the steering wheel occuring after 65mph.
Really did fool me this one - theres me thinking ive fitted an uprated part and the problem couldnt be attributed to it and it was causing the symptoms all along.
Thanks everyone for your input thoughThumbs up
Posted 24th May 2012 at 21:21
that's what they're meant to do btw, they dont work like the rubber bush, more like a bearing - bush.
Its quite known on most pugs that poly stuff isn't up to it, original rubber is far better Thumbs up
Posted 24th May 2012 at 23:13
