displaying posts 1 to 25 of 35
Author Subject: Car overheating at low speeds
vik
My car is overheating a lot at low speeds, sometimes it's OK, but most of the time once it's warmed up, will overheat after just a few minutes in traffic.
Constant warm air coming out of the vents and stinks of coolant too. Dreading head gasket problems as I'm 1000 miles from home and need to drive back in a couple of days!
One of the fans on the front doesn't seem to be coming on, is this enough to cause problems on it's own? I wouldn't have thought so?
Is there anything I can do other than topping up the coolant?
Posted 5th May 2012 at 19:04
Sounds like air block ? You need to bleed the system ? There is a bleed valve on the rad, thermostat housing and the pipes that run to the heater matrix ?
Are you loosing coolant ? If it smells of coolant inside the car then heater matrix is on its way out but this won't cause over heating ?
One fan coming on is normal the other is for aircon Thumbs up
Posted 5th May 2012 at 19:11
mattgti6phase2
If you have 2 fans they should both come on at low speed 97oC IIRC. 105oC for high speed fans again both spinning.
If you unplug the brown sensor on the thermostat housing it should cut the fans in at high speed if it does then leave it with the fans running to stop it over heating until you can get it looked at.
As above though i agree the matrix could be showing the first signs of letting go. As said try all the bleed valves with the heating on full and the fans on high.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 5th May 2012 at 20:25
darzmat
mine did this before, as said, it was an air lock, i would try bleeding it first to rule an airlock out.
Posted 5th May 2012 at 20:30
As Matt says, both the fans should run together at 97C at low speed and then 107C at high speed. Because the wiring for the fans are in series for the low speed if one fan is not working, then neither will work. In the high speed setup the fans are in parallel wiring so if one fan is broken the other will still work. Yes
My advice, top the coolant up and bleed the system then keep your eye on it til you get home. As already stated, the smell of coolant inside the car will most likely because you've got a damp footwell due to a leaking matrix so this will also need looking at on your return. Smile
Posted 6th May 2012 at 08:17
vik
Thanks, always grateful for helpful replies, will give it a go tomorrow.
Have been to STOP four or five times now though, hope i havent broken anything too badly!
Posted 6th May 2012 at 21:29
leaky matrix often goes hand in hand with a blown HG.
Posted 6th May 2012 at 21:41
This is so often the case. Yes
Posted 6th May 2012 at 22:22
vik
Update: Drove back through Europe, had to top up coolant 5 times during journey. All disappearing and no obvious leak! Surely HG?
Got off the ferry, drove 50 miles, overheat, top up rad, etc. But this time the temp doesn't come back down, wait for it to cool, overheats after 2 minutes every time. Call breakdown, diagnosis. Head gasket!
Pretty upset as I love this car, when I got it there were hardly any faults, but now have collected enough that I'll probably have to break it, which is a massive shame. The engine has only done 75k. Sad
Posted 11th May 2012 at 12:39
why break? just spend the £400 odd to fix the HG and run it for years to come?
if there's other faults that's your own fault for neglecting it.
Posted 11th May 2012 at 13:20
Agreed. Smile
Why not save it and enjoy it for some more years?
Posted 11th May 2012 at 15:31
again if you love it don't kill it,..
if you can get an engine cheep enough from a reputable source do an engine swap,..
then sell your old one?
i only suggest that because it's a proper kick when the bottom end goes after you've just forked out for the top end!
which I've heard of a few times on others Huh?
and been through myself Cry
Posted 11th May 2012 at 15:40
If you are going to break it, then you will be removing the engine anyway...
Why not just stick a decent second hand lump in there and put the car back on the road. Yes
You can pick up decent engines these days for like £300 and then you can be back behind the wheel. Thumbs up
Posted 11th May 2012 at 15:49
my mate dan has a rebuilt engine for about £350.
Posted 11th May 2012 at 15:53
Even better. Cool
What other faults does the vehicle have?
Posted 11th May 2012 at 15:55
Even better. Cool
Yes defo that would count as a reputable source! may as well get the other bits sorted too!
get them listed this lot will help you get to the bottom of the things you can't Thumbs up
Posted 11th May 2012 at 16:43
fatlapit
mate u dont even need 400 if u aint cooked it just change the headgasket and put a new set of bolts in it should be ok imo
Posted 11th May 2012 at 17:23
without a skim? Unsure
Posted 11th May 2012 at 17:30
fatlapit
Yeah like i. said if its not cooked and turned into a steam engine it will be fine
Posted 11th May 2012 at 17:43
I was always under the impression that there maybe a small amount of warping just by removing the head and is strongly advised to get the head skimmed if removing it at all?
but if you get it skimmed you can get the compression up and it'll put that tiny bit harder too! Cool
but get a second engine and you have the original for a possible future charger project etc LOL
Posted 11th May 2012 at 17:49
fatlapit
The gasket will deal with slight warping i myself have 2 spare engines tho Smile
Posted 11th May 2012 at 17:59
always needed a skim on these, its mainly corrosion not warping.
a steel gasket will not deal with warping.
Posted 11th May 2012 at 18:08
fatlapit
Sorry welshy mate but your wrong
Posted 11th May 2012 at 18:10
nope, if its warped you need a skim.
Posted 11th May 2012 at 18:12
fatlapit
Is that a forum old wives tail?
Posted 11th May 2012 at 18:13
