Author Subject: slimline fan wiring
eddy_gti6
can anyone help me with wiring in my slimline fan? Been trying to find something but can only find talk about fans for superchargers ect... No wiring diograms or what wires to join?
I have removed the big double fan unit and swaped it for a single 12" slimline fan. I want to try and use standard wiring so the fans will run off the temp sensor on the thermostate housing and also i had my standard fans wired so i could turn them on using my a/c button. Is it possible to wire it so the single fan works in the same way?
Posted 5th May 2012 at 08:45
I have two slimline ones on mine, i'm using the standard box with relays to control them.
I think that you may have to do a little working on the wiring if you are only using one fan as i think low speed normally runs both fans in series from one of the relays. I can't remember whether high speed is both fans running in parallel from one relay, or if its two relays powering a fan each.
I'm sure ive seen a wiring diagram for it at some point, i'll have a search and get back to you if i find anything useful.
My setup was easy as i basically just used the old circuitry only replacing the fans with my new ones.
I've lost my heater controls now though so i'm looking for a way to still retain the ability to turn my fans on manually with no a/c switch.
Posted 5th May 2012 at 11:41
Think thats the one. Smile
Posted 5th May 2012 at 11:55
Looking at that diagram i reckon you'd want to use the wiring for #30 for your fan, which should be the Green/Yellow wire and Mauve. That would only come on when the car wants to do high speed fan though.
Posted 5th May 2012 at 12:16
eddy_gti6
Thanks for that mate Thumbs up i will get a look next time i am down the garage. I have the old wiring there ready to fit do will give it a going over and a look through that diogram
Posted 5th May 2012 at 15:18
If i was you i think i would bridge pins 2 and 3 from the thermal switch #21, then feed that to pin 2 on #28 the relay. Then feed pin 5 from #28 to your motor, and the other wire from your motor to earth.
I think that should work, i'd probably make up my own loom for that. Smile
Posted 5th May 2012 at 22:11
just connect the new fans to the wiring same as the original ones.
what's so hard about that? LOL
Posted 5th May 2012 at 22:56
eddy_gti6
Because i have removed 2 fans and now only running 1 fan so when i join the wires to the fan there is still an uncomplete circuit LOL
Posted 5th May 2012 at 23:41
Just letting you know Chris that Mei pointed out in a different thread that the wiring diagram i put up above is for a non-ac car, so ours will be different. Doh
Posted 6th May 2012 at 07:49
eddy_gti6
Crazy I will figure something out. Will just have to get the multi meter out i think.
Posted 6th May 2012 at 13:16
russbez
i used a live from the existing fan wiring loom
multi metre ftw Yes
use the live which was only on with ignition
My Rallye project thread
Posted 8th May 2012 at 12:02
eddy_gti6
multi metre ftw Yes
Doesnt that make ur fan run all the time tho when your car is on?
Posted 8th May 2012 at 18:21
chrisd306
Eddy, have you not wired a bulb into where the 2nd fan should be to complete the circuit haha just sort of thing id expect from you haha
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 8th May 2012 at 18:28
eddy_gti6
p**s off LOL i keep going down the garage, opening the door looking at the car for abit and getting bored Laugh my ass off probs end up selling it before fcs anyway so might just bolt the front end back on and be done with it hahaha.
Posted 8th May 2012 at 19:04
chrisd306
Sell it haha what in bits you tool, another eddy_gti6 6 for breaking thread coming haha
& Audi Q5 S Line
Posted 8th May 2012 at 22:03
LOL
Posted 8th May 2012 at 22:11
eddy_gti6
LOL i was takin the p**s. Its not getting broke, am keepin it. Next car will be a bike engine kit car Cool
Posted 8th May 2012 at 22:40
