Author Subject: pas p/steering same all models????
skybluken
Need to replace mine as the pulley is buckled so need to know if same across the phases??
Cheers Ken
Diablo Phase 1 NOW DEAD
Alfa 156 2.0 JTS
Posted 2nd May 2012 at 20:19
ryangti6
As far as I know they are all the same on all Gti 6's and Rallye's across all phases but they are different to other models of 306.
Ryan
Posted 2nd May 2012 at 22:07
skybluken
Cheers, seen some on ebay will have to get 1 when paid.
Alfa 156 2.0 JTS
Posted 2nd May 2012 at 22:11
skybluken
Alfa 156 2.0 JTS
jeffers Forum Admin
Cheers Ken
If its just the pump I can't see it bein different, the difference with a 6 or Rallye is the Ram length I believe..... Unsure
Team Running Engine again!
Team Negative Camber!
Jeffers is correct. Yes
Pump is the same, ram has a separate part number due to having shorter travel to compensate for having a longer gearbox than the 5-speed varieties. Smile
Posted 2nd May 2012 at 22:14
ryangti6
Pump is different to all other 5 speed varieties too other than 16 valve Xsi as far as I know.
Ryan
Posted 2nd May 2012 at 22:37
Yes, the pump off a diesel variety is different thats for sure. However, I think the petrol ones are all the same...Unsure
Posted 2nd May 2012 at 22:39
ryangti6
I'm sure Welshpug or someone will confirm.
I know the 8 Valve Xsi, S16 and 1.8 xs's I've seen have all run different pumps to the Gti 6 and Rallye's
Either way worth making the OP aware it's worth double checking even if I am wrong.
Ryan
Posted 2nd May 2012 at 22:44
skybluken
Ta did think of just changing pulley but will probably change whole unit incase its the shaft and not just the pulley as plenty on ebay,
Alfa 156 2.0 JTS
Posted 2nd May 2012 at 23:05
birk
Im sure thugpuggin/roland rat will have some off a 6
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 3rd May 2012 at 09:14
Having looked around, it would apppear there are slight differences Ryan you were right. Thumbs up
As Birk says, there will be peeps here who have spare ones lying around, you could always put an ad in the Wanted section. Yes
Posted 3rd May 2012 at 09:52
skybluken
Cheers all, will do an ad when got the funds,
Alfa 156 2.0 JTS
Posted 3rd May 2012 at 18:04
