displaying posts 1 to 25 of 63
Pages (3): [1] 2 3
Author Subject: 307 302mm discs
JWP EFi
Turbo Legend!
whats the chances of fitting the above discs to a 306 with GTi6 calipers?....
Posted 25th Apr 2012 at 22:54
None
Posted 25th Apr 2012 at 22:56
they'll fit with 307 calipers.
but they do weigh a CHUFFING TON.
you have a diseasel, stick with the 266mm standards and good pads.
Posted 25th Apr 2012 at 23:08
JWP EFi
Turbo Legend!
already got gti6 anchors up front, and i will admit, the 283's are better but the 266's would have
done the job quite adequately! However my discs are warped.....
tbh i wasnt aware that 302mm discs were available for pugs so after hearing about it i thought it
had to be worth asking!!
Posted 25th Apr 2012 at 23:28
JWP EFi
Turbo Legend!
will the 307 calipers work with the GTI6 yolks / saddles, whatever you want to call them!
Posted 25th Apr 2012 at 23:29
no, they are specific to the caliper, you'd need the 307 carriers.
apparentlu quite rare to warp a disc, usually poor pad choice leaving deposits on the disc when they melt
Posted 25th Apr 2012 at 23:36
you need these discs for the 807v6 setup, im going to look into bells and rotors though i think if the discs are heavy
Posted 25th Apr 2012 at 23:38
JWP EFi
Turbo Legend!
...think i'll not bother with 302's, my discs and pads came from ECP, and for first few hundered miles they felt s**te but now
feel ok apart from being warped, heavy braking and deep puddle to blame me thinks!
Posted 25th Apr 2012 at 23:49
c_j_m
I've the 302's on my HDi and the discs weigh a shed load, but the do stop damn well.
Posted 28th Apr 2012 at 14:20
Is it the discs that are heavy or the calipers?
If its the discs is anyone clever enough to figure out if I can get bells and rotors in the same dimensions for a 306?
Posted 28th Apr 2012 at 23:14
both.
Posted 28th Apr 2012 at 23:16
c_j_m
Indeed, there off the car atm so can weigh them up if you want. But not sure if I've anything to weigh them on.
Posted 29th Apr 2012 at 00:27
discs weigh 8.42kg each, standard 283's weigh 5.95kg, original calipers are about 6 kg.
Posted 29th Apr 2012 at 09:36
Hmmm. Bells and rotors then, no point in 2kg calipers if the discs weigh that
Posted 29th Apr 2012 at 09:39
How wide are the 302 discs again? I think HI-spec might do rotors that would work
although this is a little off poutting. Old. but still
http://bbs.scoobynet.com/wheels-tyres-and-brakes-13/316231-dont-buy-hi-spec-brakes.html
Posted 30th Apr 2012 at 11:36
28mm i think
Posted 30th Apr 2012 at 12:25
feck.
Whats the deal with bells and rotors etc. Is it a case of all the bells for our cars are the same and the you just need rotors in the size you want?
Or do bells come suited to invidual rotor widths and sizes?
Posted 30th Apr 2012 at 13:17
eliotrw wrote:
bells come suited to individual rotor sizes
To a point, most brands have a few bolt patterns depending on the diameter of the disc+bell combo, and of course the offsets can be varied.
Posted 30th Apr 2012 at 13:22
Hmmm this is tough. I don't really get working out disc sizes etc. for example I'm sure the 807 v6 had bigger and thicker discs than that, I kind of get the difference in diameter as the hubs are not the same. but surely the thickness is thickness you know?
Posted 30th Apr 2012 at 19:26
c_j_m
Been into pug today, retail on the 807 calipers is £343 each and my local one can do them for £309.
Posted 1st May 2012 at 15:21
the mag radial mount ones? Hmm not that expensive then.
Posted 1st May 2012 at 15:32
Oh really?
I though they were 400+ each?
In that case i might just pick them up through Peugeot(I'll give Cardiff a go this time instead of Newport, they rip you off big style)
Just need to sort lighter discs now
Posted 1st May 2012 at 16:33
c_j_m
Indeed, they only list one type for the 807 I do believe, part no 4401F4/5 for left and right.
Or from here delivered for 388 Euro, but may not be genuine brembo ones.
http://seekpart24.com/budweg/brake-caliper-343664?c=100807&at=12677
Posted 1st May 2012 at 16:37
c_j_m
Also found they use the 283mm 206 gti 180 discs with the 406 brembos on the C2R2.
Posted 1st May 2012 at 16:38
they are the ones I know, Budweg Recon ones, They look very real :S I left Budweg an email earlier today about them.
Posted 1st May 2012 at 16:39
Pages (3): [1] 2 3
