Author Subject: Rear suspension skip time!
samslow
Working my way through list of todo s on the car. Currently the car sits quite low at the back with the tyres slightly into the arches. its has no suspenion travel atall. its like its on the stops and its a dog to drive. I know there is a various popular setups on here but i may put the car back to standard first.
So i may as well do the whole rear.
What do i need:-
i know the following
1.beam mounts (4 is it?)
2. rear shocks
3. get beam recon
what else do i need?
im just gonna buy everythingbit a time while cash permits and then fit all in 1 go.
thanks
sam
Diablo Gti6 ph 2 98
Posted 25th Apr 2012 at 16:40
handbrake cables Smile
Posted 25th Apr 2012 at 17:22
Rear hubs
Recon the rear brakes
New disc protectors
Hand brake cables
Discs and pads
Flexi hoses
Thumbs up
Posted 25th Apr 2012 at 17:50
Rear hubs
New disc protectors
Hand brake cables
Discs and pads
Flexi hoses
Thumbs up
sack off the disc protectors, don't need them Yes
hubs tend to last a very long time, only necessary if worn.
Posted 25th Apr 2012 at 20:28
samslow
Rear struts
best place for standard type? price?
Diablo Gti6 ph 2 98
Posted 26th Apr 2012 at 08:11
gilesy
Euro car parts, peugeot, second hand. Have a read through some of the suspension threads, will give you an idea of how much things generally cost.
How deep are your pockets?!
Posted 26th Apr 2012 at 08:40
samslow
not very at the minute otherwise i would go for billys and eibachs but modified about doubles everything doesnt it?
Diablo Gti6 ph 2 98
Posted 26th Apr 2012 at 08:43
gilesy
And the rest!!
My rear beam rebuild, xsara torsion bars and hybrid arb plus dampers is prob standing me £700+ at the moment
Posted 26th Apr 2012 at 09:01
what have you got on there now?
they are"dampers" btw, 306's don't have rear "struts"
Posted 26th Apr 2012 at 09:02
samslow
thats the word i was thinking ofThumbs up dont like shocksRoll eyes
Diablo Gti6 ph 2 98
Posted 26th Apr 2012 at 09:04
samslow
don't know what they are they look pretty rough there s barcode sticker with 2334 on but aside from that i cant tell
Diablo Gti6 ph 2 98
Posted 26th Apr 2012 at 09:07
gilesy wrote:
And the rest!!
£395 for oilite conversion xsara beam
£150 for hubs
£200 for hybrid ard
£200ish for dampners
£175 for solid mounts
ooooooooooh dear lord!!!!
Posted 26th Apr 2012 at 23:09
sod oilite, wouldn't want sticktion in there, just change the o.e bearings more often than ten years Thumbs up
your dampers are standard pug ones.
Posted 26th Apr 2012 at 23:12
miles
For once I agree with WP, Oilite is a waste of time, as dare I say the it hybrid ARB is your rebuilding a beam as the arm shafts should be able to take at least a 29mm rear bar
The other thing having started to look into it is the damper rates between the 306 and Xsara, there's a huge differance
www.pugracing.com
Posted 29th Apr 2012 at 20:00
Would you recommend using Bilstein for xsaras then miles? If Im going to have xsara tbs?
Actually. xsara billies even exist?
Personally I would go the billy eibach route. Doesn't cost that much more if anything. Solid mounts are cheaper for a start.
Having said that my beam is going to be very expensive indeed.
So far it consists of
Baker BM mounts 120 quid.
New estate bars 200
Hybrid arb 170
Bilsteins not got them yet but should be 160 for the 2
Rebuild? Don't know but I'm allowing 300. Although I've supplied most of the stuff so idk
1060 then Shock
Posted 29th Apr 2012 at 20:35
i got fed up of replacing bearings in my beams.....just wanted piece of mind so i'll deal with it
Posted 29th Apr 2012 at 22:31
whysat? fit them properly and they'll do 5 years easily.
Posted 29th Apr 2012 at 22:38
