Author Subject: Help fitting a tow bar? Electrics?
sergioiacobucci
Hi,
So thankfully I was able to get my hands on a towbar for this weekend so I can go and pick up my go kart Big grin
I was wondering if anyone had any tips for fitting it? I believe I am going to have to cut the bumper, has anyone else done this before?
Also the wiring for the electrics Confused have any ideas?
As always help much appreciated Smile
Phase 1 silver track car
335i daily
Posted 18th Apr 2012 at 01:23
calibra306
Your welcome ;-)
I would place under the car and put a bolt through either side to support allowing it to swivel. Pull out under the bumper marking with a pencil/marker where the central point is and where you would need to cut!
My bumper only needed the underside lip cut out so visually ok when I removed it!
A dremal or drill with sand paper bit would take the bumper away quite quick.
The wiring went into the drivers side rear light.
V6 Power!
Faster I can go the better!
Posted 18th Apr 2012 at 02:50
jeffers Forum Admin
Don't mean to sound funny but I'm sure I read somewhere that the DIY fitting of tow bars has now been outlawed, and it's only supposed to be approved fitting centres now that fit them....... I may be wrong but worth checking is it not?? Just my 2p's worth...... Unsure
Team Running Engine again!
Team Negative Camber!
Posted 18th Apr 2012 at 06:50
sergioiacobucci
Thanks Jeffers I'll look into it.
Calibra306 haha thanks! Didn't want to keep asking you questions! With regards to the wiring how did you know which wires go where etc?
335i daily
Posted 18th Apr 2012 at 07:32
sergioiacobucci
Would I be better off putting this in the electrics section actually?
335i daily
Posted 18th Apr 2012 at 14:58
sergioiacobucci
I found this:
I get it apart from the fact that I wire both brake lights into one and then into the towbar wiring terminal?
335i daily
Posted 18th Apr 2012 at 17:33
