displaying posts 1 to 25 of 51
Pages (3): [1] 2 3
Author Subject: I'm stumped!
mattgti6phase2
Hi guys.
Ok firstly I'm posting in general as i am unsure what the problem is as of yet. If admin feel they need to move it then feel free Yes
I wasn't going to post at all as im usually good at finding issues if they occur but today i have had a real good look and still can't find the issue so im now getting pretty p**sed off!
My 6 has developed a whirring noise it can be heard ever so slightly whilst driving in a straight line but becomes more apparent when cornering. If you turn left between 10 an 11 o'clock it occurs and the same if you turn right. The noise doesn't occur all the time and will only be apparent above 20mph.
Due to servicing just recently the car has has new wheel bearings both sides,new discs and pads front and rear new diff seals and gear oil so i have to say im lost as to what it could be. Both ball joints are less than 6 months old an i have checked for movement and there is none. The tracking was recently done when i had new tyres fitted the wheels were also balanced. Both TRES are fine also.
From what i feel by hand the driveshafts seem ok and with the car on axle stands and left to run in first gear the noise has completely gone. Then as soon as you drive it again it comes back. Everything is tight and where it should be.
So am i missing something simples or is there something more sinister at work?
Many thanks Matt.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 17th Apr 2012 at 14:03
cheapo bearings or branded?
Posted 17th Apr 2012 at 14:06
bearings still or shafts
Posted 17th Apr 2012 at 14:12
wrong / low gear oil?
Pulleys?
Posted 17th Apr 2012 at 14:17
PAS pump.
Posted 17th Apr 2012 at 14:20
wiper motor
Posted 17th Apr 2012 at 14:21
Whirring Simulator installed?
Posted 17th Apr 2012 at 14:23
most likely to be the rearmost left supermegatron above the rear subframe
Posted 17th Apr 2012 at 14:28
Paddy McGuinness trying to say "where" under your bonnet?
Posted 17th Apr 2012 at 14:32
eddiebeano
Hmm I had my suspicions
team: Stealth Ninja
Posted 17th Apr 2012 at 14:33
mattgti6phase2
SFK
5 x a 306 owner!
mattgti6phase2
Pulleys?
2.1 litres of BV pulleys are fine.
5 x a 306 owner!
matt evans
And working i suspect.
honestly3k wrote:
owain wrote:
Posted 17th Apr 2012 at 14:34
mattgti6phase2
When it whirring it can be felt through the steering wheel. So confused.
5 x a 306 owner!
Posted 17th Apr 2012 at 14:35
matt evans
PAS belt or PAS pump bearings giving up. Take the AUX belt off and see if theres any play in the pump
Posted 17th Apr 2012 at 14:36
got a solid bottom engine mount?
Posted 17th Apr 2012 at 14:49
chris1987
Don't no if it will help when I got my 6 I had Whirring noise it turned out to be low on power steering fluid .
Posted 17th Apr 2012 at 15:07
clen666
Try and get all of your driving done before 10 o'clock, you should be in bed by then anyway
Team 'unintentional rat look'
Posted 17th Apr 2012 at 15:09
aaron6
Low power steering fluid?
Posted 17th Apr 2012 at 15:12
PAS pump?
mattgti6phase2
All mounts are OE and are in a pretty good state of health.
As said the whirring occurs when turning and not all the time and you have to be doing above 20mph.
On that basis i would hazard a hazard a guess that its something that is constantly rotating and when rotating on an angle ( with steering lock applied ) it isn't happy.
5 x a 306 owner!
Posted 17th Apr 2012 at 15:37
How about the PAS pump? Anyone suggested that yet?
Posted 17th Apr 2012 at 15:39
won't be the pas pump
what about the power steering pump?
Posted 17th Apr 2012 at 15:41
PAS pump. As stated above, take the aux belt off and check for play in the pump and the idler on the same belt system. My guess is the pump is beginning to show signs of wear. Wink
Posted 17th Apr 2012 at 15:42
bo***cks, won't be that. There's a hydraulic pump on the near left side of the engine bay which runs from the aux belt, take a look at that.
Pages (3): [1] 2 3
