Author Subject: Rear Bearing Changing - help needed
gtylerroberts@manx.net
I am in the process of refurbing the rear beam. I have decided to change both of the bearings as one is gritty and the other has play.
I put the bearing in the press and the the bearing would not come out. I tried several times and in the end the hub distorted.
How much pressure should you have to put on the bearing to remove it? I was under the impression it was about 10 ton?
Also is there somewhere I can buy a hub and bearing set complete?
Also anyone found a good way of getting the back of the bearing of the stud axle?
Thanks
Posted 16th Apr 2012 at 22:17
jeffers Forum Admin
Your changing the wheel bearings I assume? If so it comes as one, ie the bearing and hub come together ready to fit to the stub axle. Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 16th Apr 2012 at 22:20
you can't remove them on disc and abs drums, if they are worn you need a complete hub.
either drift the inner race off with a chisel, or grind through it with an angle grinder, or knock the stub axle through.
Posted 16th Apr 2012 at 22:21
Thanks guys - that's great info - any suggestions on best place to purchase? Is there a forum member that supplies them?
Posted 16th Apr 2012 at 22:25
When I bought rear hubs back in 2009 when I did my beam they were £100 ea from Peugeot, I reckon they would have shot up in price now like all their other prices have. Dry
You could try factors or Euro's etc, although if it were me I would go for the Peugeot ones personally as I think they will be better quality. This theory certainly applies to wishbones. Yes
Hope this helps.
Posted 16th Apr 2012 at 22:31
Thanks Stan - that's very helpful, although not cheap!
Posted 16th Apr 2012 at 22:33
motorfactors will be fine as long as tis a recognised brand like SKF INA etc.
Thanks Welshpug - Where exactly is cwmcarn? North Mid or South Wales
Posted 16th Apr 2012 at 22:37
As Welshpug says, SKF are good I used to sell them. Yes
And INA make the tensioners for the cambelts etc so they are also a good brand. If you don't want to pay Pug prices these are good alternatives. Wink
Posted 16th Apr 2012 at 22:43
south east Smile moutainbikers will know it.
Thanks for the info - I am struggling to find a motor factors that does SKF on the Isle of Man.
That's Islands for you! Any decent online companies that you guys have had success with?
Posted 18th Apr 2012 at 19:15
allanallen
QH (quinten hazel) bearings are sometimes re-packaged skf bearings so it's worth a look in the box.
Facebook
Posted 18th Apr 2012 at 21:41
