Author Subject: Clutch cable replacement problems...
thewho07
Been following the guides in the FAQ section. Got the old cable ready to come out, string attatched, air con pipes pulled up, but it wont budge! Trying to pull it from different angles etc isnt working either! Any ideas?
Posted 16th Apr 2012 at 15:05
Weetabix
  • Posted 16th Apr 2012 at 15:11
    thewho07
    Haha i'll try that! Broken foot doest make it easier either... Thumbs down
    Posted 16th Apr 2012 at 15:13
    edit> what won't budge? the pipes?
    it's probably getting trapped under the servo on the big black grommet. i just wiggled it from the bottom whilst a mate pulled it in. didn't take very long. we just undid the aircon pipe securing clip and prized the pipes up a little bit using a massive crowbar
    Posted 16th Apr 2012 at 15:15
    smegal
    Lube it up with fairy liquid!
    Ex SC-6
    Now in a Megane R26
    Posted 16th Apr 2012 at 15:16
    thewho07
    Right. Got the new one in, nearly. Its lined up ready to get pulled through the hole. Been at it for ages and cant get it through! Ahhhh! I'll try again tomorrow. Got enough cuts on my hands for one day. Haha
    Posted 16th Apr 2012 at 17:33
    The first time you do one of these they are a nightmare as you are discovering...
    Once you've done 2 or 3 they become a doddle as you know exactly what to do. Yes
    Posted 17th Apr 2012 at 06:26
    thewho07
    Finally done it. Hope i never have to do that again! Haha. Worth it though, clutch is twice as easy to use now.
    Posted 17th Apr 2012 at 12:02
    Well done, as I say the first time has been difficult but if you do ever need to do it again you will find it easier and know how to do it. Yes
    Posted 17th Apr 2012 at 13:16
    thewho07
    Clutch is much easier to use but...
    I am struggling to select gears now. Reverse, 1st and 2nd are really hard to get. The others aren't too bad. Take it the clutch is on its way out??
    Posted 19th Apr 2012 at 16:55
    yeah could be your clutch plate,...
    that's another fun job to do!
    Stan helped me do mine i'll never forget that day! LOL
    best was when Stan decided that Jokers head could be taken off with the Exhaust manifold still attached,..(seperate job same day!)
    and it ended up with my arms sitting in between the head and the block to stop the valves touching anything,..
    while stan frantically tried to undo the bolts from the manifold from underneath think joker was running around flapping his arms in the air or something? happy days LOL
    but yeah if your going to do a new clutch defo get some help from someone that knows what their doing,..
    Posted 19th Apr 2012 at 17:06
    thewho07
    How much can I get a clutch kit for? Anything else worth replacing at the same time?
    Posted 19th Apr 2012 at 17:12
    peobably get this one for £50?,. Clicky
    there are some seals that you could replace at the same time while it's off! Smile
    Posted 19th Apr 2012 at 17:28
    Clutch release arm bushes,crank seal might need doing,drive shaft seals.
    I got a service exchange Valeo clutch kit from Pug for just over £80Wink
    Posted 24th Apr 2012 at 19:57
