It occasionally wont start but when it does it will idle fine.
The symptoms start when you drive away. Under full throttle the car seems fine until you let off. Driving normally and after backing off the car will cut out randomly, revs will slowly die similar to lambda issues. While this is happening both the rev counter and speedometer bounce around like crazy. The car sounds very rough and smells rich. It will also cut out and stall when pulling up to junctions.
So far I've tried changing the ECU, the relay behind the ECU, the cam and crank sensors and the lambda. I've also checked the voltage on pin 35 of the ECU which has battery voltage even while it's cutting out so it seems power to the ECU is fine.
Any suggestions as to where I should be looking next?
Pics of my 6My 6 on Google Video thanks to coxy306Xsi
anderoo
