Cheers!
| Author | Subject: Air scoop and passenger driveshaft |
atterz
Seasoned Pro Location: Stafford Registered: 18 Feb 2011 Posts: 1,134 Status: Offline |
As title, i need the standard air scoop for a rallye/6 so i can sort some kind of enclosed induction setup. And a drivershaft because its started clunking as i pull of since i put the solidish gearbox mount on so im assuming that may be the issue. Cheers! ________________________________________ owain wrote: A GTI-6 with a good dashboard and the seats down can outsprint an E46 M3 in July. |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
get a snorkel off someone breaking a 6/ rallye cheep enough!,.. and I'd thoroughly investigate before buying drive shafts etc,.. have you checked your engine's top mount etc? ________________________________________ Proud Member of the ASTOR Owners Club |
atterz
I havent checked the top mount cradle yet, will do this afternoon if the rain f**ks off! Its ever since i put the really stiff gearbox mount on, it wasnt there at first but it now knocks as i move off.________________________________________ owain wrote: A GTI-6 with a good dashboard and the seats down can outsprint an E46 M3 in July. |
snjbowk
Regular Location: south wales Registered: 13 Jul 2009 Posts: 311 Status: Offline |
£10 posted for the air scoop?________________________________________ breaking moonstone v plate 6!!! |
2 part Air scoop £8 posted.________________________________________ ![]() |
Could be the bottom mount is loose on the engine. The top mount cradle has never been welded by the way, but then it never needed it!________________________________________ Nothing to see here |
atterz
Good point Adam! I didnt think it had been welded and when i got it it felt loose, i didnt remove the top mount but screwed it back in and it went tight again. Best get her welded and that bottom mount replaced!________________________________________ owain wrote: A GTI-6 with a good dashboard and the seats down can outsprint an E46 M3 in July. |
Dunno what top mount is in there now. I sold it with a new baker group n one. ________________________________________ Nothing to see here |
atterz
Most certainly not in there now mate and its only changed hands the once between me and you! Ill rip it off tommorrow and fingers crossed the cheap pattern part mount has failed and not the cradle!________________________________________ owain wrote: A GTI-6 with a good dashboard and the seats down can outsprint an E46 M3 in July. |
If need driveshaft think I have one.________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
