Author Subject: R/H steering lock
darzmat
now, after having the car for 15 months or so, i understand that there is a small hydrolic ram/piston thing to
prevent the wheel from hitting the gearbox...
well... mine is not doing that, had my passengers side wheel off and i have a nice polished bolt on the end of the gearbox and a small groove worn in my brand new tyre.
what can i do to sort this??
cheers
Posted 12th Apr 2012 at 11:05
jord294
It may help, but i'd make sure your tracking is right, with almost equal adjustment on both tres
Posted 12th Apr 2012 at 11:29
darzmat
My tracking got done last month.
Will check the tre and how far in they are today.
Posted 12th Apr 2012 at 12:09
Just because your wheels are in track doesn't mean the rack is centred, if you get me. Say both wheels are actually pointing 2 degrees to the right, they're technically parallel but the ends of your steering rack will be in the wrong place Yes
Posted 12th Apr 2012 at 12:21
as mentioned, most tracking monkeys just tweak one side disregarding the effects it has on a car with relatively precise steering like a pug.
also, it could well be that your PAS ram has been replaced at some point with a standard unit which does not limit r/h lock.
Posted 12th Apr 2012 at 13:35
Or you are using wider wheels / tyres, or the brake discs aren't quite as thick. Could be engine mounts are worn too. All sorts!
Mine used to do the same thing on standard everything too.
Posted 12th Apr 2012 at 13:54
Or in the hot weather your gearbox has melted and is now an inch wider Dunno
Posted 12th Apr 2012 at 14:06
Mine was doing this too,it was the tracking not adjusted equallyWink
I've got 7x16 inch alloys with 205 tyres and get no rubbing at all nowThumbs up
Posted 12th Apr 2012 at 22:49
I'm running 17 x 7 wheels and tyres and don't have this issue.
As stated, check the threads on both TREs and make sure they are pretty equal. I take it the car drives in a straight line to start with?
Posted 19th Apr 2012 at 09:26
darzmat
It does indeed.will check it at the weekend
Posted 19th Apr 2012 at 10:28
