Author Subject: fitting backbox
hunter1983
Hi everyone got a back box fitted on my car yesterday BUT its way 2 loud iv got another 1 to put on instead just wondered how hard it is to do yourselfjust been reading the fitting an exhaust an decat thread on here an it mentions an ecu reset could anyone tell me how u do thatan if u need to with just a backbox cheers
Posted 11th Apr 2012 at 14:41
HI mate, not too hard as you can detach the backbox on its own by undoing the clamp, and taking it off after removing the mounts. Its covered in the Rear Beam Faq as you need to remove the backbox in that.
Posted 11th Apr 2012 at 16:07
piece of p**s, will take you about 10 minutes. one bolt holding the backbox clamp to the back of the centre section. undo, and wiggle the box off the 3 rubber mounts. reseal using some form of exhaust putty or paste (unless it's sleeve fitment like a Magnex)
Posted 11th Apr 2012 at 16:10
hunter1983
The backbox that's on is welded on not clamped does that make the job harder thanks for the answers
Posted 11th Apr 2012 at 17:16
darzmat
it will have to be cut off and a new one welded on
unless your on about the weld on the actual backbox, if so a few inches further down the pipe there should be a clamp
Posted 11th Apr 2012 at 17:29
Blink
There should definitely be a clamp joining the backbox to the centre section. Yes
What make of backbox is it that you had fitted?
Posted 11th Apr 2012 at 19:10
hunter1983
I can't see the make on it so not sure there is no clamp its just welded straight on
Posted 11th Apr 2012 at 19:23
Well if you're asking how hard it is to replace a backbox that can't be removed, I think you've answered your own question, would be cheaper to replace the whole thing.
Even that's not hard to do though, it's all nuts & bolts and a tube of paste from Halfords, I did it the other day and I have absolutely no idea what I'm doing.
Posted 11th Apr 2012 at 19:24
hunter1983
That makes 2 of us then ill just cut it off an go from there it would be quieter without a backbox than that noisy thing
Posted 11th Apr 2012 at 19:28
So, in effect you're telling us that whoever fitted it has now made the backbox and centre sections completely inseparable bar cutting them apart? Unsure
That isn't very good service IMO. No
Posted 11th Apr 2012 at 19:36
hunter1983
Your right ill have to make a sleeve up an hacksaw it off an clamp it sounds easy haha
Posted 11th Apr 2012 at 19:42
anth
New exhuast time Big grin
Posted 12th Apr 2012 at 07:15
Yeah I picked up a stainless one from here, mid section and back box for about £90, fitted it in ten minutes. I'd do something similar if I were you.
Posted 12th Apr 2012 at 09:33
To be fair, you could go down the new exhaust route/pick one up second hand and you would probably be happy.
However, personally I would take it back to the place that fitted it and complain that they have replaced a 3-piece system with a 2-piece one that makes removing the backbox separately impossible. All companies that make aftermarket exhausts off the shelf for the 306 make them in 3 pieces and even if you go to a custom exhaust place like Powerflow they will tailor an exhaust to your requirements but it will still be a 3-piece system.
Go back whilst the job is still fresh on their books and complain. Yes
Posted 12th Apr 2012 at 10:54
*By "3-piece" I am referring to the custom exhaust being split into 2 parts with the CAT/Decat being the third part just in case you were thinking the centre and rearbox should be in 3 parts...
Posted 12th Apr 2012 at 10:57
hunter1983
Im going get under an have a proper look this aft see what i can do might just take the advice an replace the lot while im at it powerflow want 325 quid for full decat system
Posted 12th Apr 2012 at 11:05
Bear in mind a de-cat is now an MOT fail, so if you are going down that route you'll need to make sure you can easily swap it out for a cat come MOT time.
Posted 12th Apr 2012 at 11:38
hunter1983
Oh ye hadn't thought about that well the hacksaw is coming out an the noisy box is coming off this aft iv got a custom backbox i had made a few years ago ill bang that on till i decide what im doing
Posted 12th Apr 2012 at 13:14
not in my experience, they have all been single piece from the cat back.
I know from experience that a powerflow system will fit inside a 306 for transportation in one piece as it didnt come apart.
as do Longlife systems.
magnex et al will be two part off the shelf though.
Posted 12th Apr 2012 at 13:31
hunter1983
Well iv changed the backbox over for now to the 1 i had been storing it sounds really nice now when u put your toe down but still sounds quite boomy when its idling ???? Nowhere near as bad as the other one tho
Posted 12th Apr 2012 at 17:43
What make is it?
Posted 12th Apr 2012 at 18:35
hunter1983
It was made a few years ago at a place near me called zaust i just picked the pipe an he made it up an fitted it on a saxo its for me
Posted 12th Apr 2012 at 18:38
Sounds like it'll be nothing but the finest quality.
Posted 12th Apr 2012 at 22:30
LOL
Posted 12th Apr 2012 at 22:33
