Author Subject: Correct size discs **pics added**
samslow
Evening all
been on here a while and finally got a 6 after wanting one from when they first came out. this ones could be track too hopefully. thought best join too
Anyway im working my way through list of things to do and brakes are juddering so i thought warped discs?
just took wheel off to have a look and thought front disc looks a bit small
its a 267mm or thereabouts. Arent these supposed to be 283mm std? the caliper says lucas b131 .
Has someone put the wrong discs on this?
If they have put wrong discs on it does this mean ive got wrong calipers too?
thanks
sam
Diablo Gti6 ph 2 98
Posted 10th Apr 2012 at 19:21
283x22.
lower spec models, and the older S16 used 266x20, should say Lucas and 57 on your calipers if they are the proper gti6 ones.
Posted 10th Apr 2012 at 19:23
samslow
well
discs are 266 x20
and caliper says lucas 5856/1 and lower down says 8131 ( well thats what it looks like anyway)
havent got caliper off yet to check piston size as bolts are solid so might have to soak em for a bit
Diablo Gti6 ph 2 98
Posted 10th Apr 2012 at 19:58
Sounds like someones been tight and fitted 266mm discs on there.
Is there any lip on the pads?
Posted 10th Apr 2012 at 20:00
samslow
sorry how do you mean?
Diablo Gti6 ph 2 98
Posted 10th Apr 2012 at 20:01
samslow
on 2nd thoughts i presume you mean extra pad sticking out over top of disc?
and yes there is!
mines a 98 S phase 2 not that should make any difference
Diablo Gti6 ph 2 98
Posted 10th Apr 2012 at 20:04
honestly3k
I had major juddering on my brakes recently, when the old disc came off there was a visable and noticeable to the touch ridge all the way around the inside of the disc so something must've scored all the way around it and warped it something cronic. Disc was only a couple K old too.
Anyway fresh discs and pads all round and shes now braking wonderfully Smile
If you can post some pics up of your caliper people should be able to tell you if its a gti6 caliper
Posted 10th Apr 2012 at 20:12
yup, you need to post pics, does it have 5 or 6 gears btw?...
Posted 10th Apr 2012 at 20:16
samslow
tis 6 speed v5 says gti6 and everything seems to match up
crappy light in my garage cant get a decent pic will try
Diablo Gti6 ph 2 98
Posted 10th Apr 2012 at 20:26
samslow
pics!
Diablo Gti6 ph 2 98
Posted 10th Apr 2012 at 21:03
bloody hell Laugh my ass off
I didnt thin anyone would be quite so daft as to do that!!
definitely time for a new set of discs and pads there!
Posted 10th Apr 2012 at 21:05
samslow
that was my plan anyway before this.
so is it fair to assume that someone has cut cost/bought wrong discs.
when i looked on gsf they only list a 266mm disc where as eurocarparts list it on my reg as 283mm!
Diablo Gti6 ph 2 98
Posted 10th Apr 2012 at 21:13
scotzman
You can get the correct ones from GSF, but you have to search under xsara vts
Posted 10th Apr 2012 at 21:16
have a look on ngsf under this part number
601PC0211
They're on special right now, £19 each, pretty good price.
these are the premium pads from them afaik.
642PC0542
Posted 10th Apr 2012 at 21:19
scotzman
The premium discs used to be Brembo's, not sure if they still are
premium pads were girling iirc.
Posted 10th Apr 2012 at 21:22
samslow
601PC0211
642PC0542
thanks
so am i to conclude calipers are correct but just wrong discs?
Diablo Gti6 ph 2 98
Posted 10th Apr 2012 at 21:23
they do indeed look correct, I don't know any other 306 caliper that has those fins over the caliper body, between those you should see the numbers 57.
Posted 10th Apr 2012 at 21:30
rob_humphrey
They Look an awful lot like my calipers on my hdi tbh mate Hmm
Team Moonstone Big grin
Team Working Aircon
Posted 10th Apr 2012 at 22:25
samslow
just looked again and YES i can see 57!! phew! so just wrong discs then thankfully!
Diablo Gti6 ph 2 98
Posted 11th Apr 2012 at 08:41
matt evans
Jeez, some bodgers about.
Still, i bet half the pads are like new? LOL
honestly3k wrote:
owain wrote:
Posted 11th Apr 2012 at 09:01
yes ive had this on the first 6 i bought,bloody tight gits out there Dry
Posted 11th Apr 2012 at 09:15
LOL
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 11th Apr 2012 at 11:25
samslow
601PC0211
642PC0542
well ive just bought the discs! bargain at £38!!
didnt buy the pads as ive been told there is 3 different types for gti6 is this right?
Diablo Gti6 ph 2 98
Posted 11th Apr 2012 at 13:59
Just file or grind the lip of the old
Ones LOL
Posted 11th Apr 2012 at 18:59
I'm fairly certain the discs I had fitted for a mot are wrong too, I just don't have the stomach to check.
Posted 11th Apr 2012 at 19:16
