Author Subject: Bump steer
peugeot96
Have any a good idea how to reduce bump steer on a lowered 306?
Posted 7th Apr 2012 at 18:20
raise the ride height Thumbs up
Posted 7th Apr 2012 at 18:27
playboyb
^^^^^^^^ haha quality advice!
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 7th Apr 2012 at 20:24
peugeot96
Hehe, Im running coilovers now and lowered to much and I dont like it at all. Will now fit max 30mm springs.
Do you know the lenkarm angle with Eibachs?
Posted 7th Apr 2012 at 20:51
with eibach's they sit quite flat.
though if you are on height adjustable coilovers, just raise the ride height.
Posted 7th Apr 2012 at 20:57
peugeot96
I have a set of Bilstein b6/8. Didnt like the shocks on my Supersport coilovers. But need advice about springs.
Does the vts have the same springs as the 306?
Posted 7th Apr 2012 at 21:04
no, phase 1 vts springs are said to lower a 306 by circa 25mm, unsure of spring rate.
Posted 7th Apr 2012 at 21:10
peugeot96
One more thing, does the vts rack fit the 306(5speed) without any modifications?
Posted 7th Apr 2012 at 21:32
yes.
Posted 7th Apr 2012 at 21:44
peugeot96
yes.
Great help.
Thanks
Posted 7th Apr 2012 at 21:50
Can you make up some spacers to raise the height of the steering rack?
Posted 8th Apr 2012 at 10:08
no, the rack bolts are horizontal not vertical, you'd need to modify the subframe to raise the rack.
Posted 8th Apr 2012 at 10:13
^What he said, I drilled through the subframe to move the rack and then tweaked it back and forth with some shim steel until I was happy it was back straight.
Posted 8th Apr 2012 at 10:18
Ah, I stand corrected Smile
Posted 8th Apr 2012 at 10:25
Hold on, so I can get vts eibachs for my 306 with b8s and they will lower it buy about 25mm as opposed to 30.
Using all 306 parts in the strut?
Posted 8th Apr 2012 at 12:50
no, standard vts springs, not vts eibachs, they'll drop a 306 probably 50mm or more.
Posted 8th Apr 2012 at 13:05
Ohhhhhhhh I see, I will have a think about that one
Posted 9th Apr 2012 at 13:50
anth
If you want it lowered on the cheap eibachs and buy some new b4s
Posted 14th Apr 2012 at 11:24
