Author Subject: urgent head removal advice
6waysforward
Ok just about to whip the head off but the haynes manual says remove the cam covers and spray bars, Do the spray bars need to be removed and if so how??
Secondly and most importantly the haynes manual says remove the head bolts of a spiral starting from the outside working in but which side do i start on 1st and do i do the 2 on one side, then 2 on the other side, then back to the other side etc etc or do i do one on one side, the one on the other Anyone got a idiot proof drawwing with arrows asap??
I have done a search but i can find much and im in a blind panic to get it off before dark. Thanks.
Posted 7th Apr 2012 at 16:56
allanallen
Spray bars just pull out, it's just a little o-ring holding them in.
Spiral the head bolts from either side first, 2 from one side then the other etc etc. just crack them all off first then go round and loosen them.
I'm sure there must be a guide in the F&Q.
Al
Facebook
Posted 7th Apr 2012 at 17:14
6waysforward
That's what I thought but I didn't want to warp my good head. Thanks.
Posted 7th Apr 2012 at 17:56
fatlapit
do it in reverse of this
http://www.306gti6.com/forum/showthread.php?id=61411
Posted 7th Apr 2012 at 17:59
6waysforward
fatlapit wrote:
I can only see 10 head bolts but that pic shows 18 Confused
Posted 7th Apr 2012 at 18:52
There are only 10 head bolts. Yes
Posted 7th Apr 2012 at 19:37
fatlapit
sorry yes there are only 10 mate
Posted 7th Apr 2012 at 19:39
6waysforward
For a moment there i was s hitting a brick LOL
Posted 7th Apr 2012 at 19:57
fatlapit
u need a female torx bit though mate
Posted 7th Apr 2012 at 20:00
or a male one if its a later engine.
Posted 7th Apr 2012 at 20:06
6waysforward
Was just going to use a 12mm 6 sider but thought better of it LOL
Posted 7th Apr 2012 at 20:49
6waysforward
I am taking apart my old engine out of a ph2 as it had quite a bit of money thron at it by the previous owner. New gaskets, pump and belt, fly wheel and pulley etc and dropping it in my ph3 Smile
Posted 7th Apr 2012 at 20:51
bit of a waste taking the head off really unless its leaking, don't forget new bolts, and if you get the ones with captive washers you don't need to use the original washers.
Posted 7th Apr 2012 at 21:00
6waysforward
Well i wana do the gasket while the engine out but i don't think it needs it. but i want to do it because i found a few receipts and apparently the engine has had new pistons and lots of head work. After taking off the inlet manifold, it looks like its had work done but i want to know if its decently got forged pistons etc.
Posted 8th Apr 2012 at 19:12
