Author Subject: Garage clearout 205 + 306 parts
alastairh
Hello,
Time to clear my garage ready for a new project. All items listed bar the engine and axle are pictured on my photo bucket site here - http://s1175.photobu...!cpZZ1QQtppZZ20
Sorry for such a long post! Items located in Kettering Northants, any questions etc, just drop me a message.
205 / 309
309 23mm rear anti roll bar – Orignal 306 length item, professionally cut down and resplinded for 205 end plated. £80 or £90 delivered.
205 Battery tray – Black. Light surface rust. £12 delivered.
205 GTI 8v oil breather cap. £5 delivered.
205 GTI 8v afm bracket. From the back of the afm to the battery tray. £12 delivered.
Lower Xu engine alloy mount with standard Pug GTI6 bush pressed in. Used. In good condition. £15 delivered.
205 Slam panel. Fairly mint and original. Removed from a 31k auto at the local scrappy years ago. £20 posted.
205 Strut brace. Alloy, Etec of similar brand off the top of my head. £35 posted.
205 GTi charcoal canister. Removed from inner wing of a K-93 car. Kept as a spare to retro fit for GTI6 conversion. £20 delivered.
Be3 clutch pedal and clutch cable new. Ideal Be1 – Be3 conversion. £25 posted.
205 GTI Phase 2 header tank. Includes switch. £15 posted.
205 GTi front subframe. Good straight condition. £25 posted.
205 GTi non pas square drive steering rack. Working condition. £25 posted.
205 GTi Dials. 123k recorded. From a later car with numbers on the oil pressure gauge. £15 delivered.
205 GTi Phase 2 door looms. Plug and play for 1.6 owners with electric window motors. Rather rare. £28 posted.
205 GTI smooth wheel arch and door trims. Black, NSF trim is broken and needs work / replacement. Ideally suit a respray, but the hard work of detexturing is done. £35 delivered.
205 GTi 1.6 and 1.9 passenger short drive shafts. Working order. £28 delivered each.
309 GTI De pas steering rack with new track rod ends. £35 delivered.
205 GTI black smooth side badges. £15 posted.
205 GTi6 oil pressure adaptor. Brand new from Pugracing. £10 delivered.
205 GTi BBM Solid rear beam sandwich mounts. £23 delivered.
205 GTi Black smoked side repeaters. £8 delivered.
205 GTI Electric central locking motor kit. All three units tested and working. £25 posted.
205 GTi rear wash wipe fuller bottle and pump. £10 posted.
205 GTI Phase 1.5 Grey dash. As pictured. £30 collection only.
306 GTi6 + Xsara VTS
306 GTi6 283mm callipers, discs, pads and bolts. Free bleed nipples etc, ready to use. £70 delivered.
Xsara VTS XU10J4RS engine. Removed from Phase 2 multiplex car. 65k, no tapping, burning, overheating or knocking. Solid engine complete with manifolds etc. £350 collected.
Xsara VTS Rear axle. 65k, Not seized, fitted with 21mm torsion bars as standard. Includes callipers etc. £150 collected.
306 GTi6 gear box. Removed from working car. No whining or crunching. Tested as it was my run around car over the winter. £80 collected.
306 GTi6 steel spare wheel. Includes Pirelli P6000 with 4-5mm tread. £25 posted.
306 GTi6 Phase 3 electric window motors. Both tested and fine. £25 each or £40 collected. £6 postage either way.
306 Gti6 and Xsara VTS 2 port master cylinder. Choice of both style locating fitment. £20 delivered.
306 GTI6 Phase 3 fuel pump. Tested and fine. £25 delivered.
306 GTI6 exhaust cam. Removed from a 70k car. In fine order £25 delivered.
306 Phase 3 electric wing mirrors. Black. £25 posted.
Xsara VTS engine looms x2 £25 posted each.
306 GTI6 phase 3 engine loom. £25 posted.
306 GTi6 slim line starter motors X2. Tested and fine. £25 posted.
306 GTi6 airbox kit. Complete with all hoses and brackets. £25 posted.
306 GTI6 Phase 3 parcel shelf with speakers. £25 posted.
306 / Xsara VTS PAS pipes. The main one that runs from the pump, down the front and bottom of engine and to the rack with sensor. Often damaged from bottoming out. £25 posted.
306 GTi6 / Xsara VTS Rear heater matrix hoses with working clip. £15 posted.
306 GTi6 Phase 3 radiator. Valeo. Recently replaced but with fitment and storage marks. Good working order, including bottom hose. £45 delivered.
306 GTi6 induction hose with good condition ICV connection pipe. £12 posted.
306 GTi6 battery box with lids. £20 posted.
306 GTi6 Bosch ABS pump. Removed from a phase 3 car, working. £20 posted.
306 GTi6 cambelt covers and coil pack covers. £7 delivered each.
306 GTi6 phase 3 slam panel. Straight good condition, £30 delivered.
306 GTI6 steering rack with lower UJ and ram. Good working condition. £35 posted.
306 GTI6 electric window and mirror switch. Phase 3. £8 posted.
306 GTI6 Phase 3 Cam pulleys, £15 delivered x2 sets.
306 GTi6 / Xsara VTS Phase 1 top engine mount arm. £15 delivered x4
306 GTi6 3 pin Knock sensor. Ideal anyone using a phase 2 Xsara VTS engine to run earlier non multiplex management. £20 delivered.
Xsara VTS Phase 1 Fog lamps. Mint. £20 delivered.
306 GTi6 Crystal clear side repeaters. £8 delivered.
Misc
16 row oil cooler, sandwich plate and blanking winter pipe work. Used as pictured. £25 delivered. No pipes.
10” Genuine SPAL cooling fan. Used, good working condition. £35 posted.
Thanks
Al
205 GTI6
Primera GT
Xsara VTS
306 GTI6
Posted 5th Apr 2012 at 15:26
alastairh
http://s1175.photobucket.com/albums/r638/Alastairm87/#!cpZZ1QQtppZZ20
Link above!
Al
205 GTI6
Primera GT
Xsara VTS
306 GTI6
Posted 5th Apr 2012 at 15:41
pugpower1986
alrigt pal have you got the exhaust system for the gti6? need one for my rallye cheers pal Smile
98 Cherry Rallye
98 cherry 106 gti
Te@m Cherry Smile
Posted 5th Apr 2012 at 15:45
barnettjd77
do you have the spare still wheel?
A red rallye in progress!
Posted 5th Apr 2012 at 17:28
gazzerdaman
1st dibs on the engine
Gary
Cherry Red GTi 6
Posted 5th Apr 2012 at 18:02
alastairh
barnettjd77 and gary, you both have pm's.
pugpower1986, I don't have a complete system, sorry.
Thanks
Al
205 GTI6
Primera GT
Xsara VTS
306 GTI6
Posted 6th Apr 2012 at 16:40
mpieczko
Hello mate, I'm wondering if you've got a pair of headlight wiring covers to suit phase 2 headlights?
I think these covers are the same as on phase 3 crystal headlights but not sure.
Posted 7th Apr 2012 at 11:41
