2000 'W' GTi-6
| Author | Subject: phase 3 radiator |
jonv
Seasoned Pro Location: Thame Registered: 19 Feb 2006 Posts: 1,088 Status: Offline |
as above - decent 2nd hand one would be great.________________________________________ 2000 'W' GTi-6 |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
jonv wrote: as above - decent 2nd hand one would be great. any 6 radiator should fit but you need to know what you bottom hose connection is? there are 2! and if your gona get another radiator i'd get a nissens one like this one! Ebay one £125 all in in all honesty mate a radiator isnt something you want to skimp on! that goes and you can bye to your head gasket!![]() ________________________________________ Proud Member of the ASTOR Owners Club |
snjbowk
Regular Location: south wales Registered: 13 Jul 2009 Posts: 311 Status: Offline |
i got a minter off a 1999 6.£50 posted________________________________________ breaking moonstone v plate 6!!! |
jonv
thanks for that - i think a new one would be sufficient - is there an easy way of seeing which connector i have without getting under the car?gnrlee wrote: jonv wrote: as above - decent 2nd hand one would be great. any 6 radiator should fit but you need to know what you bottom hose connection is? there are 2! and if your gona get another radiator i'd get a nissens one like this one! Ebay one £125 all in in all honesty mate a radiator isnt something you want to skimp on! that goes and you can bye to your head gasket!![]() ________________________________________ 2000 'W' GTi-6 |
from mid phase2 they were the metal clip type, if you are unsure just buy a new bottom hose for about £22+vat, comes with new o-ring.the linky is for the very early type. you want this type http://www.ebay.co.uk/itm/NISSENS-Radiator-PEUGEOT-306-2-0-GTI-XU10J4RS-96-97-/310334733525?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4841643cd5 ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
gnrlee
few small tips!if you go for the later push in type with a retaining clip use some silicon sealant around the metal bathroom silicone from wilco should suffice, before pushing it in it makes for a much better seal! and gently roll the pipe in mini circles as you massage it in to stop the O-Ring from twisting and not creating a good enough seal! and to fit it's much easier if you remove the headlight/grille/Slam panel,.. ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
no need for any sealant, just a new o-ring.bathroom stuff is probably the worst stuff to use too. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
gnrlee
welshpug! wrote: no need for any sealant, just a new o-ring. bathroom stuff is probably the worst stuff to use too. don't see why? let it set! it just aids the seal a little better doesn't it? I got new O-Ring went in fine,. eventually dripped like a mo-fo!used sealant Job Jobbed! not a problem since! ________________________________________ Proud Member of the ASTOR Owners Club |
jonv
at the risk of sounding thick - it has 93-96 on that one - mine is a 2000they compatible? gnrlee wrote: jonv wrote: as above - decent 2nd hand one would be great. any 6 radiator should fit but you need to know what you bottom hose connection is? there are 2! and if your gona get another radiator i'd get a nissens one like this one! Ebay one £125 all in in all honesty mate a radiator isnt something you want to skimp on! that goes and you can bye to your head gasket!![]() ________________________________________ 2000 'W' GTi-6 |
I'd just do as WP suggested. Buy a new pipe and do them together.For the price of the pipe it's good piece of mind that it will seal well. ________________________________________ ![]() |
fatlapit
Location: STOCKSFIELD Registered: 02 Nov 2010 Posts: 3,040 Status: Offline |
unless i`m a mong i have always needed a dab of silicone too________________________________________ |
![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
T400 PUG
Banned!Location: Burnley Registered: 01 Jan 1970 Posts: 641 Status: Offline |
ive got a nearly new nissens rad which is in very good condition but ive poked four holes through the fins to mount a slimline fan to it. Makes no operational difference just might look alarming. £75 posted. plus i have a nearly new pug bottom hose to go with it if you want £10 so £85 all in.Ive only ever used a bit of moly grease on the bottom joint as it gets rusted shut otherwise which makes removing an old rad a total b**ch without cutting bottom hose off. |
mjm3043
Regular Location: inverness Registered: 26 Mar 2009 Posts: 195 Status: Offline |
I have a nissens. Along with a good bottom hose, will do it all in for £70 delivered. |
