Author Subject: lambda sensor and exhaust
hunter1983
Anyone know where the lambda sensor plug at the back of my engine bay should be plugged in its just dangling doing nothing, and could anyone shed any light on why my standard exhaust system is vibrating at 3000rpm doesn't do it above or below just 3000 an its annoying
Posted 27th Mar 2012 at 16:30
mattgti6phase2
The lambda clips onto the body work behind the battery or to the side I'll have a look on mine and confirm. If the clip is broken and fallen off then there will be a square hole there IIRC.
As for the exhaust it could be rubbing against the heat shields underneath the car or the bumper and is only vibrating when its reaches the said rpm because of the tone being quite deep at around 3k.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 27th Mar 2012 at 17:49
hunter1983
Cheers mate ill have look at weekend hopefully sort it out
Posted 27th Mar 2012 at 18:01
mattgti6phase2
Check all the exhaust rubber mounts as they perish and sag causing the exhaust to move.
5 x a 306 owner!
Posted 27th Mar 2012 at 18:15
mattgti6phase2
If your looking under the bonnet it's just to the right of the heater matrix pipes on the bulk head it's deffo a square hole.
5 x a 306 owner!
Posted 27th Mar 2012 at 18:26
hunter1983
Ok thanks for the help mate ill have a look tomoz
Posted 27th Mar 2012 at 20:08
