Author Subject: Judder
Evening,
I've got what I'm sure is clutch judder when letting the clutch outThumbs down
Just wanted to see if anyone has had juddder which has ended up being something other than the clutch(eng mounts etc)?
Posted 25th Mar 2012 at 20:48
Unfortunately....deffo the clutch plate mate...Sad
Posted 25th Mar 2012 at 22:07
Ok cheersThumbs up
My gearbox has got a rumble at idle too,so kill two birds with one stone I supposeRoll eyes
Posted 25th Mar 2012 at 22:09
When you say rumble, it could be the clutch release bearing in which case you would be changing that anyway. Or does it sound more sinister than that?
Posted 25th Mar 2012 at 23:08
jeffers Forum Admin
Mines juddered since I bought the car with 43k on it..... (now on 110kDunno) although it probs needs changing now.... Almost deffo clutch plate mate and the rumbling could be release bearing..... At a rough guess!
Team Running Engine again!
Team Negative Camber!
Posted 25th Mar 2012 at 23:29
Mine juddered since i bought it at 88k too, now on 110k also Razz
Posted 25th Mar 2012 at 23:32
Defo need to change the clutch if it's juddering on pull away ? Do the cable as well as they dry out and cause the clutch to be heavy
Yeah will bang a new cable on and mount while its out.
Yeah the rumble is from further along the box than the bell housing,does not change when you depress/release clutchWink
I've used my special listening device to diagnose it,a screwdriver on box and me sticking my ear on the handle!!!Whistle
I did this because it sounded like a bottom end engine rumbleNo but luckily its deffo in boxYes
Posted 26th Mar 2012 at 22:09
Could be one of the internal bearings then. Sad
So I take it you are looking to change the box at the same time as you do the clutch then?
Posted 27th Mar 2012 at 22:22
YeahThumbs up
Kill two birds with one stoneYes
Posted 27th Mar 2012 at 22:27
tony1991
I have a judder when pulling away in first I have just changed the clutch when I fitted new engine everything is sweet other than that. Is it something I could have done wrong fitting the clutch?
Posted 31st May 2012 at 20:23
Was it a brand new clutch kit?
Posted 31st May 2012 at 20:34
tony1991
brand new fitted tuesday an put shaft on to day. my back brakes are sticking a little which i will realease tomorow i dont no if that could be a problem but when i seen this thread fort i would see
Posted 31st May 2012 at 20:37
Could be sticky back brakes, but if it definitely feels like it comes from the front of the car then check your engine mounts for excessive play.
The other thing it could be is the clutch pressure plate. Did you evenly torque it down onto the flywheel when you fitted it?
Posted 31st May 2012 at 21:25
tony1991
yer il have a little look an sort brakes out. yer i did each bolt few turns at a time till it was tight
Posted 31st May 2012 at 21:29
After abit of searching on here aparently the flywheel can cause the judder,slightly distortedThumbs down
Needs surface skimming when a new clutch is fitted ideallyWink
I've bought a RichW flywheel to put in mine when I get round to doing clutch/box......Whistle
Posted 31st May 2012 at 22:24
