displaying posts 1 to 25 of 38
Author Subject: Suspension geometry setup
eddiebeano
Hi guys, a quick question about geometry setup. The spec will be as follows..
-D2 coilovers with adjustable camber top mounts
-Rich W roller bearing wishbone bushes
-Upper and lower Strut Braces
-21mm torsion bars, currently at standard ride height.
-solid rear beam mounts
-205 bilstein tarmac Dampers
-hopefully hybrid arb soon too..
-55 profile hankook ventus primes, soon to be changed for something a little stiffer/stickier.
I was intending on taking the car to Progrip in falkirk as they seem to have a good rep, but what settings would folk recommend, in terms of ride height (f+r), camber settings, toe settings etc. Currently stripped out so riding high Hmm . The car is a daily but will be used at knockhill too.
team: Stealth Ninja
Posted 20th Mar 2012 at 13:16
20mm rear drop 10mm rake to front on sill jacking point heights.
camber setting depends on tyres, but 1.5 is a good place to start, toe is very much personal preference but parallel is a good place to start.
Posted 20th Mar 2012 at 13:27
eddiebeano
So, 30mm on the front? Why do you specify it by sill jacking points? The car currently looks like a tractor with nothing in it.
I'd like the wheels to fill the arches, hence I'll be keeping 55 profiles whatever I go for.
After reading this.. http://www.ozebiz.com.au/racetech/theory/align.html it would seem a touch of toe out would be appropriate, and a small amount of negative camber? i don't want it to eat through tyres anyway.
Ed
team: Stealth Ninja
Posted 20th Mar 2012 at 13:47
specified at sill jacking points as the front+rear arches have a different profile.
Posted 20th Mar 2012 at 14:50
eddiebeano
you learn a new thing every dayThumbs up I'm taking your advice on board, but can't help thinking it's still going to look too high with just a 20mm drop on the rearDunno
team: Stealth Ninja
Posted 20th Mar 2012 at 15:45
depends, do you want it to handle or not ? LOL
Posted 20th Mar 2012 at 16:32
eddiebeano
of course, it's why I bought the car, but looks are important too. Why are most of the track cars in projects section lowered significantly more than 20 mm then? I'm thinking of Owains, Russian Guy's, and numerous others. Basically I'd rather have a track slag and suffer the consequences of using it as a daily. For example, this is the stance I would be after..
How much do you reckon that is lowered?
team: Stealth Ninja
Posted 20th Mar 2012 at 16:43
too much LOL
Posted 20th Mar 2012 at 16:57
eddiebeano
too much LOL
Looks awsome thoughLove I assume if you're basing a spec for track, rather than a daily, lowering more than 25mil is acceptable! The only chance i get to drive B roads is once in a blue moon, which is a shame...
team: Stealth Ninja
Posted 20th Mar 2012 at 17:10
I had a rallye here a week ago and it was sitting much like that one, wishbones were pointing skywards and the bumpstop on the rear was less than a fingers width away from the trailing arm, it rode bloody awful.
lowering more than 25mm without a lot of chassis work is silly regardless of track or road use.
Posted 20th Mar 2012 at 17:15
eddiebeano
Ok I will certainly bear this in mind! Anyone else care to ad their opinion?
team: Stealth Ninja
Posted 20th Mar 2012 at 17:21
But sure the minimum you can lower the front is 3cm? Without coilovers....
Posted 20th Mar 2012 at 17:24
eddiebeano
Reading the project thread for above car, he says he's tried raising and lowering the car but 45mm, as it's sat in the pic, seems to handle the best.
team: Stealth Ninja
Posted 21st Mar 2012 at 10:45
Handling and grip are two different things.
Posted 21st Mar 2012 at 10:53
I bet that car above is running 50 profiles anyway.
Anything from 20-30mm on the rear as its already stripped out. You do want some rake forwards on it but too much will make it the rear end nervous on turn-in. What springs on the front?
A lot of the cars in the project section are track cars, but its up to you how much you compromise road compliance for track grip. Handling sweetness can be sorted for both but balance is the most important bit.
Posted 21st Mar 2012 at 10:58
eddiebeano
Stupidly I couldn't tell you what spring rate is on the front.. So if it was lowered 30 on the back and 40 on the front I think that would be a good compromise. Any idea what suspension settings you would specify Adam? In terms of toe and camber.
team: Stealth Ninja
Posted 21st Mar 2012 at 11:38
Not really no. You don't have a great deal of options. I think mine was always slightly toe in but I didn't have camber/castor adjust. Making sure the rear beam is square on is quite important. I think you need a bigger rear arb before anything else.
The volvo runs: camber -1 on the front, -2 on the rear, toe slightly in front, rear changes depending on load. Must fit those rear camber bolts...
Posted 21st Mar 2012 at 12:13
dan86
I run mine with 20 minutes toe-in on the front. It makes the turn in nice and sharp. I've tried parallel which was less sharp and had to turn the steering wheel a bit more to get the same response and toe-out was quite numb feeling but was very stable feeling espescially over crests and under hard braking.
Personal preference really. My front tyres always seem to wear flat and evenly with the setting I have.
Posted 21st Mar 2012 at 12:51
eddiebeano
Would you say the toe out made it unstable and likely to wander in a straight line?
team: Stealth Ninja
Posted 21st Mar 2012 at 13:01
dan86
No, toe out was more stable. Toe in makes the steering response sharper, but not unstable by any means. It just requires less steering input to get the same result. Toe-in FTW.
Posted 21st Mar 2012 at 18:38
clen666
I thought the opposite was true Dunno
Team 'unintentional rat look'
Posted 21st Mar 2012 at 19:07
eddiebeano
Hmm toe out should make steering turn in sharper as the wheel on the inside is already facing in the direction of turn. At least that's what I've read.
team: Stealth Ninja
Posted 21st Mar 2012 at 19:17
mik
...but the car's weight is more on the outside wheel in a corner, so toe-in on the front wheels will mean the outside wheel is already pointing slightly in the direction of turn. Toe out will give the opposite.
Cherry Rallye SOLD
Posted 21st Mar 2012 at 19:49
woody.
Toe out for more straight line stability, toe in for better cornering. That's vaguely how I've been taught!?
eddiebeano
The above guide says..
team: Stealth Ninja
Posted 21st Mar 2012 at 19:55
