Author Subject: *Help* GTI 6 rear suspension lower on one side ????
tom28
Just discovered after admiring my 6 that the wheel arch gap on the drivers side of the car (ONLY AT THE REAR,) is smaller than the passengers, so much so that it is quite noticeable when each side is compared.
what could be wrong??
Posted 16th Mar 2012 at 18:41
Level ground? e.g flat and not a slight road camber.
Posted 16th Mar 2012 at 18:46
tom28
Yep, actually parked it up on two different spots to make sure i wasn't going crazy, but both were flat surfaces and the gap stayed the same Sad
Posted 16th Mar 2012 at 19:02
darkstar753
Mine is similar, pretty sure one side has more camber than the other too. Paranoid that its a wonky rear beam (bearing in mind I have no idea what the symptoms of that may be)
Darkstar
Posted 16th Mar 2012 at 19:11
jeffers Forum Admin
Moved to suspension section! Smile
Team Running Engine again!
Team Negative Camber!
tom28
could it be a worn damper??
Posted 16th Mar 2012 at 19:27
danposs86
I came on here to ask the exact same question.
Drivers side rear lower than passenger side rear.
Hope it is just the shocks. The rear is very soft and bouncy (have adjustable konis, however there isn't much different between settings).
danposs86's GTi-6
Posted 16th Mar 2012 at 19:29
Rix13
mines the same, have a very small amount of chamber on passengers side but all drives fine so ive just put up with it.
www.eastcoastmodified.org
E46 318i tourer SE - Dog Car/Work horse
306 Gti - Track Project
Posted 16th Mar 2012 at 19:33
tom28
correct me if i'm wrong, but i was under the impression the rear didn't have springs (awaits the inevitable flaming) Whistle
Posted 16th Mar 2012 at 19:35
darkstar753
its got torsion bars but still has dampers like any other car, otherwise you would be bouncing all over the place!
Darkstar
Posted 16th Mar 2012 at 19:52
tom28
Sweet, so is there anything else that might be at fault apart from worn dampers? (kinda abit relieved now though as other people seem to have experienced/or are experiencing the same problem) How could i go about resolving the issue or is it nothing to worry about Dunno
Posted 16th Mar 2012 at 20:00
a torsion bar is a spring, just not a "coil" spring.
most likely to be worn trailing arm bearings, a damper would not cause it unless one was seized.
Posted 16th Mar 2012 at 22:26
scotzman
My 205 was like this, someone had been messing around with the torsion bars before I got it, all sorted now thoug Smile
Posted 16th Mar 2012 at 22:33
tom28
Thx everyone for your input Thumbs up
Posted 16th Mar 2012 at 22:40
tom28
oh well looks like another trip to the fooking garage then
Posted 16th Mar 2012 at 22:43
tom28
"most likely to be worn trailing arm bearings, a damper would not cause it unless one was seized"
By bearing do you mean BUSH ?
Posted 16th Mar 2012 at 22:59
nope, I mean bearing.
Posted 16th Mar 2012 at 23:01
tom28
where can i get one from/how much for 1
if possible can you do a link to it and post a picture.
soz for the persistant demands LOL
I want to understand whats wrong so i can fix it
Posted 16th Mar 2012 at 23:08
peugeot Smile
Posted 16th Mar 2012 at 23:14
