displaying posts 26 to 35 of 35
Pages (2): 1 [2]
Author Subject: decided to go for a Rich W flywheel :)
T400 PUG Banned!
eliotrw wrote:
Sorry for a silly question. but i think I know where my oil is going now... Sad
Oh well, I always look for excuses to do things like that so i'll pick up a flywheel.
How much would it cost for a garage to do that seal do you think?
your leak is probably caused by the seal in the end piece of block casing. meaning sump needs to come off and new OE strip seals and auto- joint. then new crank end seal and flywheel on.
Posted 13th Mar 2012 at 22:01
Stuwee
honestly3k wrote:
Steering wheel wobbles on throttle in 3rd/4th/5th/6th when giving it the beans since i did my ball joints.
Would you say thats cos tracking is out?
Driveshaft inner joint not happy
Ph1 Cossack 6
Posted 13th Mar 2012 at 22:07
mattgti6phase2
Stuwee wrote:
Driveshaft.
+1 for driveshaft. Normally driver side as that's the shaft most of the power is sent to.
How early we talking Chris?
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 13th Mar 2012 at 22:09
honestly3k
Thats what i was afraid of Doh
I lost about a litre of gearbox oil when i changed the balljoints and just pushed it back in so would you think the shake is the result of it not seating properly? Will i have wrecked the gearbox seal?
Saying that im fairly certain im not losing any gearbox oil on a day to day basis.... Drivers side didnt come out when i did that ball joint, but then it cant can it?
Posted 13th Mar 2012 at 22:45
honestly3k
Stuwee wrote:
Driveshaft.
Early as you can do fella. I imagine it will take about 2-3 hours to do so maybe a 10am start?!
Posted 13th Mar 2012 at 22:46
Stuwee
What you have most likely done is broke the spring in the inner d/s joint on either the n/s or o/s. My bet would be the n/s joint. The spring reduces the movement of the shaft in the joint.
Ph1 Cossack 6
Posted 13th Mar 2012 at 23:00
mattgti6phase2
Stuwee wrote:
Driveshaft.
2-3 hours to do brakes?? Shock
Half that really if you include the rears. As your above post the shake from putting the shaft back in will have made no difference. If you damaged the seal you'd know about it.
When my driveshaft shat itself it nearly shook the car to pieces. I'll do my best to be up early. I'm watch the Australian f1 qualy live and that starts at 6am I think Wink
5 x a 306 owner!
Posted 13th Mar 2012 at 23:03
honestly3k
Anyone know the service box part number of said spring? Is it easy to replace? Might get a chance to look at it when we're doing brakes...
Ok's Matt well we could do them earlier if you want then you can go back to bed after LOL
Could prob do later than 10am though. Not sure what time I'm setting off for southampton, dependent on when my mates wana set off!
Looks like I ballsed up yet another diy job on the car with this shake, should just stick to removing wheels....oh wait I can't do that properly either! Doh
Posted 13th Mar 2012 at 23:14
Stuwee
Spring part of the inner joint i think. New shaft time.
Ph1 Cossack 6
Posted 13th Mar 2012 at 23:19
honestly3k
Post #35
Ah I see....most likely the ns shaft then after I man handled it? Can only be that one really as I didn't touch drivers side as its secured in isn't it?
Posted 13th Mar 2012 at 23:24
Pages (2): 1 [2]
