displaying posts 1 to 25 of 33
Author Subject: servo pump removal
fatlapit
has anyone done this??? is there a big difference????willit run without it???
Dunno Dunno Dunno Dunno Dunno Dunno Dunno Dunno Dunno
Posted 8th Mar 2012 at 21:19
Well, there is a big difference. Try rolling along in your car without the engine running and then pressing the brakes. You will find that very little happens and it takes A LOT of effort on the brakes to bring it to a stop.
Why do you want to remove it anyway? Unsure
Posted 9th Mar 2012 at 07:26
if you do ditch it, swap to another MC setup and proper pedal box Yes
Posted 9th Mar 2012 at 14:47
chris with a pug
If you get the right sized MC's then it should be ok.
Posted 9th Mar 2012 at 20:41
fatlapit
It looks gash and is very untidy. not sure it would like the heat from turbo.
Posted 9th Mar 2012 at 21:42
birk
Easy to remove with engine out.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 10th Mar 2012 at 02:06
fatlapit
removed the servo pump and tbh honest i believe it does jack sh*t f*ck all tbh.
Posted 7th Apr 2012 at 17:48
Blink
Posted 7th Apr 2012 at 22:09
atterz
Please remember guys he is talking about the pump on the end of the cam and not the actual servo.
owain wrote:
Posted 7th Apr 2012 at 22:16
Are you sure? Dunno
Posted 7th Apr 2012 at 22:20
fatlapit
Yup the pump attached to the cam doesnt really do alot. unless mine is worn a bit
Posted 7th Apr 2012 at 23:38
Ok, I understand now. Thumbs up
I thought you meant the servo unit itself. Shock LOL
Posted 8th Apr 2012 at 09:57
they don't need to do a lot, but they do enough to run the brake servo.
Posted 8th Apr 2012 at 10:02
atterz
It will be working fine as i imagine at the moment you are taking a vacuum line from the inlet manifold, im not sure it will work when the manifold is pressurised though? What do petrol turbos normally do in that situation?
Posted 8th Apr 2012 at 12:05
fatlapit
One way valve mate between the inlet and servo
Posted 8th Apr 2012 at 18:00
Why do these engines have a pump?Dunno
And also a pipe to the inlet?Dunno
Your not using the brakes when the turbo is boosting!!!!!Smile
So inlet is at vacuum like any petrol engine when off throttleWink
Posted 14th Apr 2012 at 23:03
fatlapit
I tried it on a standard set up mate made no real noticable difference tbh.
Posted 14th Apr 2012 at 23:05
Yeah thats why I wondered why they have oneThumbs up
Don't see them on other 2ltr 16v petrol enginesDunno
Posted 14th Apr 2012 at 23:08
fatlapit
True mate very true. But saying that you do get them on diesel cars alot.
Posted 14th Apr 2012 at 23:29
The reason they are fitted to diesel engined vehicles is because the inlet on a diesel is not under vacuum it is constantly open to atmospheric pressure so you need a separate pump to create the vacuum. Yes
Posted 15th Apr 2012 at 07:30
you see them on lots of newer stuff, also the Mi16 had them.
Posted 15th Apr 2012 at 07:36
why though?
vaux xe's,ford's 2ltrs dont have themDunno
Posted 17th Apr 2012 at 12:57
to work the over servoed brakes of modern vehicles with all their egr crap etc.
Posted 17th Apr 2012 at 13:00
306 Rxs
Having a vacuum pump helps to maintain vacuum along all the use of the engine.
The gti6 has two vacuum sources, wich is better for the servo and master cylinder, letting them do their job only.
In my 306, after installing the big brake kit, i've switch off the inlet manifold vacuum pick up, so that the pedal could be more hard and less sensitive. It was good for me because, with all the vacuum on, braking with control on track conditions, was a bit complicated.
Now i only use the vacuum pump as source, and i'm aproving that.
What is a hybrid?
Honda engine...Ford brakes...Peugeot chassis...Vauxhall steering...
Posted 25th Apr 2012 at 11:22
Pump just makes the servo effect more consistant under all conditions tbh.
Posted 25th Apr 2012 at 11:25
