displaying posts 1 to 25 of 40
Author Subject: V-power... hesitation?
thewho07
Filled the car with V-power the other day, £75 worth! Thumbs down
Anyway, everytime I start the car and pull away it hesitates for a couple of seconds, after that its fine. Only noticed it since I filled with V-power though. Seems worse when it's a cold start.
Any ideas?
Posted 3rd Mar 2012 at 17:57
Seems at bit odd ?
Try normal fuel see if it's the same ?
Posted 3rd Mar 2012 at 18:07
I always run V-Power without exception, never had a problem...
As Chris says, try running on normal fuel again and see what happens. Smile
Posted 3rd Mar 2012 at 18:09
unlikely to be the fuel, but have you tried an ecu re-set?
Posted 3rd Mar 2012 at 18:41
darzmat
the guy mpaul that had my car before me put in v-power and he had the same problem. from then on he just filled up with normal fuel.
ive not tried v power but i do use the super unleaded from sainsburys (although i dont notice a difference)
Posted 3rd Mar 2012 at 18:44
I use V-Power in both my car and bike....and always have done. It seems to have a different smell when you put the fuel in than normal unleaded and even other brands of super.
I mainly use it for the cleaning detergents to be honest. Smile
Posted 3rd Mar 2012 at 18:55
allesclar
v power ftw. Smile
Team allesclar ®
Posted 3rd Mar 2012 at 19:13
m306
i run super and ive got cold start hesitation like youve described but i dont think its the fuel. ive been running on it for 4 months and only recently had the problem.
personally id say neither of us have our problems caused by the fuel. have you considered other parts that can cause cold start hesitation?
supercharged China gti6 - Thu 16th Sep 1999 - sold
2010 megane rs250
Posted 3rd Mar 2012 at 19:41
thewho07
What should i look at first?
Posted 3rd Mar 2012 at 19:42
m306
stan_306gti6 wrote:
The hesitation could be down to a lambda fault, or due to the fact it appears just after startup it could be the CTS has gone bad and is not supplying the engine with fuel enrichment.
thats one possible explanation stan gave for mine, its something i know nothing about but theres alot of guys here who should be able to help
2010 megane rs250
Posted 3rd Mar 2012 at 19:52
atterz
I know what you mean about vpower smelling different stan, weird but it does seem different to normal fuel.
owain wrote:
Posted 3rd Mar 2012 at 21:11
Yep, it certainly smells different, quite a nice smell too I think. LOL
At least with a different smell you definitely know you're putting V-Power in. Smile
Posted 3rd Mar 2012 at 23:05
mattgti6phase2
Its a waste of time using the higher octane fuels. It makes no difference at all. Also the 97 is no cleaner than 95 so there are no benefits there.
The hesitation you may be experiencing will be due to the fact that 97 Resists ignition more than 95 fuel. Basically the higher the octane rating the more you engine will struggle to ignite the fuel.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 4th Mar 2012 at 11:22
I was once going to use V-Power but I too hesitated. I then just used normal Tesco 95 RON and saved a load of money.
Maybe it was your engine going "Really?"
Unless you're running boost, in which case fair play.
Posted 4th Mar 2012 at 12:09
allesclar
So for a super-charged 306 i should be using the 95 octane fuels as the premium stuff makes no difference?
If you say so Thumbs up
Team allesclar ®
Posted 4th Mar 2012 at 12:10
BOOM
Posted 4th Mar 2012 at 12:13
mattgti6phase2
Sorry sir I didn't realise you were boosted Laugh my ass off in that case 97 and above FTW Thumbs up
5 x a 306 owner!
Posted 4th Mar 2012 at 12:16
allesclar
Razz
Team allesclar ®
Posted 4th Mar 2012 at 12:18
Any ideas?
Have you used this tankful yet and tried standard unleaded again? Interested to know if the issue was resolved by changing the fuel back to normal 95...
Posted 9th Mar 2012 at 09:03
aaron6
The map for charged 6's is using high octane but if your car were to be mapped to 95, I'm sure that would be fine. In fact, it would be interesting to see if there is a power drop.
Posted 9th Mar 2012 at 09:31
Standard cars are mapped to accept 95 or 97, although the handbook does advise to use 97. Yes
Obviously when a separate map is created then you should run with whatever fuel it was mapped on. Wink
Posted 9th Mar 2012 at 10:32
woody.
So why is it better to run 97 octane fuel on a boosted 6's? Just wondering really
Posted 9th Mar 2012 at 11:28
Lower octane fuels ignite more easily, so putting 95 in a car whose ECU is expecting fuel to not burn so easily can literally blow up your engine in seconds, as the fuel ignites before the piston reaches the top of the stroke.
Pre-ignition or knock, can't remember which one. Pre-ignition I think.
It's not that it's better, it's that it's absolutely essential if that's what your engine has been mapped for.
Posted 9th Mar 2012 at 11:30
^^This
I would add that higher octane fuels can take more compression then lower octane fuels. It is therefore why you should use it in high compression engines, or engines that are low compression at build stage but when running boost create huge cylinder pressures requiring fuel that will take more pressure before self-ignitinng and causing detonation. Yes
Posted 9th Mar 2012 at 11:36
Knock is when the fuel ignites before the spark has been introduced. Caused by having too low octane rating or high intake air temps.
Posted 9th Mar 2012 at 11:39
