Personally, I use V-Power specifically due to the advanced cleaning agents in the fuel (so they claim) being present.
"Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6
2000 (X), Moonstone
displaying posts 26 to 40 of 40
Pages (2): 1 [2]
| Author | Subject: V-power... hesitation? |
stan_306gti6
The reason that the vehicle handbook suggests running on 97 is because the '6' engine in standard form is 10.8:1 compression which is fairly high. However, due to the fact that a lot of people will just run normal 95 regardless of the suggestion the engine has been set up with a knock sensor to compensate for the possible different fuel choice of the owner. With this, the ECU can detect when detonation is about to occur and retard the ignition timing...Personally, I use V-Power specifically due to the advanced cleaning agents in the fuel (so they claim) being present. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
adam b wrote: Knock is when the fuel ignites before the spark has been introduced. Caused by having too low octane rating or high intake air temps. Incorrect They're often confused, but knock and pre-ignition are *not* the same thing. Knock is an incorrect or uneven burn (but initiated by the spark plug) whereas pre-ignition is caused by wrong fuel or over-compression; i.e. when the fuel is ignited by pressure rather than a spark. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
owain wrote: adam b wrote: Knock is when the fuel ignites before the spark has been introduced. Caused by having too low octane rating or high intake air temps. Incorrect They're often confused, but knock and pre-ignition are *not* the same thing. Knock is an incorrect or uneven burn (but initiated by the spark plug) whereas pre-ignition is caused by wrong fuel or over-compression; i.e. when the fuel is ignited by pressure rather than a spark. Fair enough. You'd better go and change a load of pages i've just read on the internet then ________________________________________ Nothing to see here |
stan_306gti6
'Knocking' is where the fuel/air combination begins to combust in the correct manner initiated by the firing of the spark plug, but some of the mixture explodes outside the area of the main flame front.'Pre-ignition' is where the fuel/air combination is ignited in the combustion chamber without the help of a spark plug. This can be caused by extreme pressures (mixed with low octane fuels), hot spots in the chamber or incorrect temperature of spark plug selected. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
ive been invited to stick my oar inthe higher octane is created by adding percentages of other chemicals mainly bio-alcahols like ethanol and methanol. essentially its a gimik of sorts these also act as detergents to a degree as they are solvents. however its possible they could melt or corrode other parts of the fuel system creating "stuff" to make deposits further along the system. my friends mev rocket exploded a fuel line that had been softened because he was using morrisons stuff with a percentage bio-fuel added. ________________________________________ the world is changed by people in sheds |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
Cheers for the info lads |
mattgti6phase2
Seasoned Pro Location: inside my 6 abusing the tarmac!! Registered: 16 Jul 2010 Posts: 2,371 Status: Offline |
stan_306gti6 wrote: Personally, I use V-Power specifically due to the advanced cleaning agents in the fuel (so they claim) being present. V power is no cleaner than 95 sir. ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
stan_306gti6
mattgti6phase2 wrote: stan_306gti6 wrote: Personally, I use V-Power specifically due to the advanced cleaning agents in the fuel (so they claim) being present. V power is no cleaner than 95 sir. Reference to origin of information Matt? ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mattgti6phase2
Perhaps the way 97 fuels are marketed lead people to believe all these out ragious statements ![]() In actual fact the main difference between the 2 are the anti knock properties being better in 97 fuels over 95. I have used both fuels and even tescos w*nky 99 fuel and the difference is nothing on my internally standard engine. Although I do find my engine is happier to run on 95. Again my engine internally is standard. ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
stan_306gti6
Post #35
mattgti6phase2 wrote: Perhaps the way 97 fuels are marketed lead people to believe all these out ragious statements ![]() There have been tests done where people have bench ran engines with a twin-tank setup. One tank of standard 95 is feeding two cylinders and V-Power is feeding the other two. It ran like this for weeks, and then they stripped it down. The V-Power cylinders were A LOT cleaner than the ones that had been run on standard fuel. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mattgti6phase2
Post #36
This debate is pointless Its simple, no power gains are to be had unless your SC TB or turbo'd and your Ecu has been set to run that fuel. Deffo no cleaner between the two though.unless i saw evidence of it, fuel experts say the cleaning differences are nil. ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
swiftyboi006
Post #37
But stan just said it was tested? (stan you must be talking bulls**t) ![]() ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
stan_306gti6
Post #38
swiftyboi006 wrote: (stan you must be talking bulls**t) ![]() Obviously mate, after all what do I know about these things... ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mattgti6phase2
Post #39
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
Post #40
Could it not just be the Lambda Sensor on its way out? ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
Pages (2): 1 [2]
