displaying posts 1 to 25 of 35
Author Subject: Knock From Lock to Lock
smegal
I am getting a knock on the near side when going over bumps.
I also noticed a knock when going from lock to lock. Does this point to top mount bearings?
Ex SC-6
Now in a Megane R26
Posted 1st Mar 2012 at 21:59
scotzman
I'm getting similar, only just started, first time i move the steering to full lock I get a clunk then it doesnt seem to do it again until the next time i drive it.
Posted 1st Mar 2012 at 22:10
smegal
That could be a spring either on its way out or not seating properly.
Ex SC-6
Now in a Megane R26
Posted 1st Mar 2012 at 22:28
Smeagal I've had the same for about 15k. I've pretty much decided its the beam mounts. But I'm getting a new beam soon anyway... but mine sounds like its the rear
Posted 1st Mar 2012 at 22:32
scotzman
to be honest thats what it feels and sounds like
Posted 1st Mar 2012 at 22:33
smegal
Mine has a rebuilt beam on solid mounts so shouldn't be that.
Ex SC-6
Now in a Megane R26
Posted 1st Mar 2012 at 22:43
Top Mount bearings or gearbox mount could be another culprit. However, out of the two options I would suspect the bearings. Yes
Posted 2nd Mar 2012 at 02:44
smegal
That is good and bad news. For some reason I had suspected the GB mount. What makes that more likely as well, is that the top mount is chocked, the bottom is group-N and the GB mount is 14 years old.
Ex SC-6
Now in a Megane R26
Posted 2nd Mar 2012 at 05:25
jimmyhackers
i had the same problem after i lowered my car with coilovers. The back of the bottom connection of the drop links was catching on the suspension arms. Spent about 2mins with a file on each plastic droplink and the noise stopped.
Posted 2nd Mar 2012 at 05:46
By having that setup, you are putting even more strain on the already aged and standard GB mount...Yes
I would personally change it just for the peace of mind that its done and see if your noise disappears. It may not be that, but at least once you've changed it you know it will be good for a while yet. Smile
Posted 2nd Mar 2012 at 13:02
smegal
The GB mount looks pretty easy too. Will get it done when I get a chance.
Thanks
Ex SC-6
Now in a Megane R26
Posted 2nd Mar 2012 at 13:08
It should take you about 15 mins to change Craig...Yes
Then you can eliminate it out of the equation.
Posted 2nd Mar 2012 at 18:55
Have you made any progress with this yet Craig?
Posted 8th Mar 2012 at 11:18
smegal
I've tracked down the part. I'll either fit it or get it fitted after next week as I am off skiing.
I am loathe to pay someone to do such an easy job, but I don't have my tools with me and the petrol to drive home or to my old uni is more than it is likely to cost to get it fitted.
The more I listen, the more I hope that the GB mount alone will sort it.
Ex SC-6
Now in a Megane R26
Posted 8th Mar 2012 at 11:24
Ok, good luck with it. Like you say its a shame to have to pay out for that but hopefully it will solve the problem. Yes
Posted 8th Mar 2012 at 12:29
honestly3k
Checked your drop links?
Posted 8th Mar 2012 at 12:34
smegal
They are rose jointed with reasonably new joints. My next point of call will be ARB bushes.
Ex SC-6
Now in a Megane R26
Posted 8th Mar 2012 at 13:48
smegal
Thanks for your advice, Stan and others.
I did the gearbox mount yesterday and the knock has gone.
Ex SC-6
Now in a Megane R26
Posted 19th Mar 2012 at 09:04
Excellent result. Smile
Posted 19th Mar 2012 at 12:52
davewagon
Just to add to this thread rather than create a new one:
I have developed a single knock recently which occurs when reversing out of parking spaces mostly.
If I reverse out of a parking space to my left, as I over come the inertia to drive forward and go from left lock to right, I'll get a clunk/knock.
Is this likely to be springs?, ball joints?
Drop links are fairly new, so I'll rule them out for time being (although i'm just listing my basic knowledge of suspension here so it's probably nowt to do with anything)
Any ideas? please
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 19th Mar 2012 at 13:31
Is it only apparant when you are moving backwards and then want to go forwards? Or can you get this knock if you are stationary and you turn the steering wheel?
Posted 19th Mar 2012 at 13:41
davewagon
Erm I'll say yes for the time being, only apparent when going forward after having travelled backwards.
I don't tend to just turn the wheels while stationary so couldn't rule it out, but i haven't noticed the noise while say turning after sitting at a junction??
Posted 19th Mar 2012 at 13:48
Check the top engine mount cradle isn't cracked. Sounds like it could be to me. Sad
Posted 19th Mar 2012 at 14:06
davewagon
Argh no!!
Could do without that bill right now tbh!
Novice question, how can I check this has or hasn't cracked (please be as detailed as you can be bothered to be)
Vaguely remember having to jack up engine??
Posted 19th Mar 2012 at 14:16
support the engine, remove the mounting arm, remove the engine mounting and look at the cradle part attached to the inner wing.
Posted 19th Mar 2012 at 14:17
