Author Subject: Throttle bodies with a misfire/hesitation
gti6boy
I built the car about 2 years ago with brand new bodies and it's driven faultless the whole time
A couple of days ago the car started to misfire slightly at low revs and spit flames out the bodies. I had exactly the same problem on the 205 cabriolet but I can't remember how I fixed it.
I have tried 3 coil packs, plugs and water temp sensor. The only other thing I think it could be is the tps but this was also new
Here is a video
http://i147.photobucket.com/albums/r295/gti6boy/45e54cd9.mp4
Thanks
Posted 25th Feb 2012 at 21:23
Crank sensor or coolant temp sensor? Ie thinking engine is cold so running rich?
Edit: noticed you have tried that Doh
Posted 25th Feb 2012 at 21:28
gti6boy
Did the video work?
Think it's running a bit rich yes
Same symptom hot or cold
Posted 25th Feb 2012 at 21:40
Dan's one did similar, it as the engine block buggered leaking coolant, HG would give similar symptoms.
Posted 25th Feb 2012 at 23:17
Is it mapped off the TPS?
If it's worn slightly the setting can drift and the massive ignition advance under light loads and openings will make it fire back up the inlet.
Posted 26th Feb 2012 at 01:29
gti6girl
Welshpug, would a compression test, test this?
Phillipm, not quite sure what you mean? Tps was set a percentage then the car mapped on the road
Posted 26th Feb 2012 at 01:39
Is the car purely mapped from the TPS sensor though, or does it use the MAP too?
MAP too should correct slightly for TPS drift, whereas if it's just from the TPS it could well be that..
Posted 26th Feb 2012 at 01:44
Moved to engines. Smile
Posted 26th Feb 2012 at 07:24
gti6girl
Thanks stan, it would not let me post in engines
I belive if the tps go's a couple of percent out it runs funny so it could be that
Posted 26th Feb 2012 at 09:23
gti6girl
Cars been sat over night. Fired up and run sweet for 20 sec then started to miss fire.
Then something strange happened, the fuel hose from the pressure regulator to fuel hose started leaking?
Could this be fuel related?
Posted 26th Feb 2012 at 11:04
gti6girl
Just took it out for a spin. Foot flat to the floor in 3rd and it pulls round to 4k then splutters but pulls through it. Does not do it every time
Posted 26th Feb 2012 at 12:29
mabgti
NV motors
Sounds like your timings out.. Or your injectos are on their way out.. What fpr and injectors is it rinning?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 26th Feb 2012 at 12:30
gti6girl
Fpr is one of them adjustable jobbies but was never new
Injectors are standard
Posted 26th Feb 2012 at 12:56
mabgti
NV motors
Why has it been mapped on a rising rate fpr? This could be your problem.. Utilise the oe 3bar and check
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 26th Feb 2012 at 13:37
yup, ditch the adjustable fpr, pain in the ass they are.
Posted 26th Feb 2012 at 15:21
gti6girl
As I said never had a problem with any of my cars running with this item. I can't put a 3 bar on there as it's been mapped to this one and I don't have access to a mapper any more or parts so trying to fix just whats broken.
Posted 26th Feb 2012 at 16:52
matty_rallye
I had a similar problem with mine a year of so back. With the DTA management it requires an air temp sensor which on mine is mounted just infront of the inlet. The sensor failed and caused it to miss up to about 4k rpm and then it would pull past it.
2.1 16v 306 Rallye.
Posted 26th Feb 2012 at 17:20
gti6girl
Popped the car over to track and road and there was a spike on the map
The battery packed up last week so could have been from that
Posted 1st Mar 2012 at 23:04
