Cheers olly
cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD
Black p3
| Author | Subject: BMC CDA induction |
swiftyboi006
Got a bmc cda induction kit, not fitted yet and woderd what peoples views are o these compared to others Cheers olly ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
anth
They do the job I had a fairly large one and it got on my tits as it kept ripping the air intake as it was quite close to the road.I found viper using the original air intake worked best. I had the intake at the fog light at one stage but it made next to f*ck all difference apart from the constant added fear of puddles which p*ssed me off as well |
swiftyboi006
I dont have the original aur intake box otherwise i would use it. Im not sure where im goin to put the cold feed atm :-s________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
anth
I dont mean the box I mean the snorkel I think I have one at home if you want it. |
swiftyboi006
Ive got a p1 not sure if its the same? Could you put a pic up and how much delivered?________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
stan_306gti6
Provided you have a good cold air feed, the enclosed setups like this offer the best performance over standard. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
anth
swiftyboi006 wrote: Ive got a p1 not sure if its the same? Could you put a pic up and how much delivered? Il get one tomorrow I dont want anything for it just cover the postage. |
swiftyboi006
Thanks again stan you so far have proven a great admin ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,311 Status: Offline |
i have a viper which ive routed to the fog light hole and i find it works well........tends to work even better when your cold air feed pipe is soild i.e metal or double silicon because it doesn't compress under load________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
swiftyboi006
I was thinking about a silicone feed for that exact reason. Phase 1 for is square tho so cant realy feed it there it will look odd________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
swiftyboi006 wrote: I was thinking about a silicone feed for that exact reason. Phase 1 for is square tho so cant realy feed it there it will look odd morrettes ![]() ________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
swiftyboi006
Lol i thought about them but there hard to get for a good price in good cond. also is it worth the money just for a cold air feed? Is the phase 1 snokel the same as phase 2/3________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
anth
swiftyboi006
Using that snorkel would be ideal for me but wouldnt it heat up from the radiator also heating the air befor it got to the bmc?Thanks for the pics anth il have a think. How much would the postage be? ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
swiftyboi006
anth
f*ck knows ? LolYour get some heat but I didn't notice any difference using this method to a fog light. It's a fairly reliable setup after all the standard setup produces 167hp ![]() Drop me a pm if you want it |
aaron6
Modified standard airbox with k & n panel filter ftw!________________________________________ See the sheer power and might of the lesser known burrowing owl. |
swiftyboi006
Ye maybe.....anyone want to buy a bmc induction lol________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
swiftyboi006
Got it fitted wen i got home from work, had to jack the car up ![]() ![]() Sounds very quiet but it does feel alot more sucky if that makes sence lol now just need to think about the cold air feed. I dont think the standard snorkel will work???? ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
mabgti
NV motors Location: Bham tunnel @7400rpm Registered: 28 Aug 2003 Posts: 9,127 Status: Offline |
A cold air feed is a must with a large enough intake otherwise youll be strangling power. The standard gti6 intake is a work of art imo.. And all it needs is a free flow air filter![]() ________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
swiftyboi006
Well it does get cold air as its about 150mm from the floor so all the air that goes under the car gets suked up.________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
swiftyboi006 wrote: Well it does get cold air as its about 150mm from the floor so all the air that goes under the car gets suked up. and water? ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
daver6
I'm gonna bump this again.I've also got a CDA kit, but I'm guessing it somehow fell out of the cradle or it was in a crash as its smashed to bits and has a fibreglass repair. My question is, should I relocate my battery and sort this properly or just get a standard box back on it. I'm a big fan of the standard box like ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
swiftyboi006
Standard box i had this 2 weeks and didnt like it________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
daver6
I'm sick of f**king around with mine, standard and BMC filter will go on once I source an airbox________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
