displaying posts 1 to 25 of 30
Author Subject: loose gear stick?
Demograffix.com
my gear stick has just gone loose, the gear box seems to be working as I can drive the car, I think it could be the linkages? any idea on how much this might cost to fix as I dont want to get ripped off at my local garageDunno
stevenage black gti 6, 198bhp
Posted 20th Feb 2012 at 18:32
swiftyboi006
Ur asking how much it might cost but yet you dont know what it is. If its a gear linkage then i would expect a garage to charge you an hours labour + the linkage its self. If it still changes gear fine then dont worry Thumbs up
Black p3 Love
Posted 20th Feb 2012 at 20:11
anth
Perfect time for some nice linkages from miles on here and a compbrake quick shift Wink
Posted 20th Feb 2012 at 20:30
combination of rods and gear stick bushes
Posted 20th Feb 2012 at 21:58
You need to look inside the engine bay, down behind the gearbox. You will see 3 rods each with "ball" cup ends.
Make sure these are all attached to their corresponding "ball". If they are, and as far as I can make out you can get every gear so they should be, then my guess is they could be somewhat worn. Yes
Posted 21st Feb 2012 at 15:14
info@pug1off.com
Sounds like the rubber ball may have fallen off of the subrame swivel bracket, or 1 of the small linkages as the other guys mentioned.
N/A XU10J4RS = 302.1 bhp / 184.2 lb.ft
Turbo XU10J4RS = 500.2 bhp / 443 lb.ft
USC 2011 Double Class winners
N/A FWD 0-60 winners at TRAX 2011
Developers, stockists and installers of superior upgrades for the Peugeot 306 GTi6 & Rallye, including:-
*NEW!!!!! 4.8:1 final drive for BE3/6
*BBM Group N engine mounts
*Cat Cams and vernier pulleys
*Emerald ECU's
*Jenvey throttle bodies
*Uprated gear linkages and short shifts
*Quaife & Tran-X LSD's for BE3/6
*Tar-Ox brake discs and Ferodo DS2500 pads
*Solid rear beam mounts
*21-25mm torsion bars
*25mm rear anti roll bars
Posted 21st Feb 2012 at 21:54
Kyle
Quick one...
Here's a photo of mine... When I reach down and give that big shaft from the gearstick a shake it moves up/down about 80mm.. Not good I take it!
What s**t do I need to replace? Is there supposed to be a rubber bush in that eyelet?
Posted 18th Sep 2012 at 12:14
wtf is going on down there?!
Posted 18th Sep 2012 at 13:28
Kyle wrote:
Quick one...
Epic bodge by the looks of the wire holding it together!!LOL
The round ball on the arm in this pic should be in the cylinder shaped piece on the end of the rod from the gearlever:
http://www.306gti6.com/forum/showthread.php?id=102217
Posted 18th Sep 2012 at 20:46
footah212
Mine ain't got that rubber bit that's held in the tube bit with the tie wire.
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 18th Sep 2012 at 21:06
Kyle
Thanks guys! Yeah pulled out the old link elbow just now.. While pulling the battery box out I found a needle stick (not mine lol).. Yeah heroin junkie for sure..
No idea what that black plastic knob is off, but obviously homebrew setup for sure!
New part ordered from local-ish peugeot dealer.. $80aus!
Does the new one still need to be secured with tie wire?
Posted 19th Sep 2012 at 03:03
no Laugh my ass off
Posted 19th Sep 2012 at 08:42
Erm?
Most definitely not! LOL
Posted 19th Sep 2012 at 09:04
tvrfan007
Epic bodgery there. I sees you're from Muswellbrook - I was there for Liddell Power Station in 2010 lol. It's an..er... interesting place!
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 19th Sep 2012 at 12:22
Kyle
Haha it's not that bad!
I bought the car as-is 2 weeks ago for $1400AU... (going rate is ~5-6kau for a good cond one) Hence the epic bodgyness haha
Posted 19th Sep 2012 at 22:56
Kyle
New linkage turned up today.. $80aud though stung a bit..
1/2 hour later and it's smooth as butter!
Hopefully the compbrake quick shifter turns up next week too
Posted 21st Sep 2012 at 04:46
Pretty much my thoughts to the word LOL
Posted 21st Sep 2012 at 07:06
rich306
Holy crap, even i wouldn't bodge it that bad Razz
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 21st Sep 2012 at 08:03
Kyle
Yeap.. it was farked for sure.. The coney looking thing that was the replacement for the rubber ball, I have NFI what is was off!?! haha
All is sweeet now though!
Posted 21st Sep 2012 at 08:06
Got one on mine,like itThumbs up
Just be aware the collars need welding onto the gearstick,I tried thread lock and drilling a pilot hole in the gearstick and they still came looseRoll eyes
No probs once welded on though!Big grin
Posted 21st Sep 2012 at 10:06
Kyle
Yeah, will throw some bird s**t on it once we got the right size...
Ready for it to turn up now though, car is on stands to replace lower engine mount too..
What length have you got yours set to?
Posted 21st Sep 2012 at 10:25
Didn't measure it sozNo
The pivot point is higher on the quickshift,there is a patterned part on the gearstick where the plastic ball sits that you need to take off,I've set mine so the patterned part is just above the lower collar on the quickshift.
The only downside to the quickshift is sorting out the lift up reverse cable holderThumbs down
I had to cut mine with a hacksaw blade to remove it off gearstick,you then need to use a small hose clip to hold it back in place on the gearstick,I also found after doing this the lift up reverse collar was not returning back down on its own,so I had to file some off the cable holder to allow it to returnRoll eyes
Important that it does return,otherwise you could select reverse when going forwards!Thumbs down
Posted 21st Sep 2012 at 14:08
you might be able to use the cable holder off a 205, its secured by a roll pin.
Posted 21st Sep 2012 at 15:33
ah right,good solution if it fitsThumbs up
Posted 21st Sep 2012 at 17:37
LOL
A bit worrying, just as you shift out of 5th at high rpm looking for top gear!
Posted 21st Sep 2012 at 19:10
