Author Subject: Unusual braking
billyboy99
To celebrate my 6's one year anniversary, i took the car for a drive yesterday and the ABS light came on (the orange light with skid marks), it stayed on for 30 mins until i stopped, then disappeared, then returned this morning. it gets worse...
...when braking in neutral, the brakes feel hollow, like im pressing the petal on bare metal and makes a noise as such.
braking in gear thus far feels normal.
assumings its related to ABS light.
(and there was extra smoking coming out of exhaust)
any tips guys?
Posted 15th Feb 2012 at 14:05
How often are you in neutral while braking? Unsure
Posted 15th Feb 2012 at 14:11
billyboy99
its a habit...as is changing gears with clutch down in corners...bad i know but my driving isnt the issue here Sad
the brakes have always worked fine in neutral
Posted 15th Feb 2012 at 14:14
More to the point, why don't you?
Posted 15th Feb 2012 at 14:28
Because doing anything in neutral uses more fuel.
Subscribed.
Posted 15th Feb 2012 at 14:36
billyboy99
Subscribed.
erm, no shirley you use less petrol in neutral as gear revs are on 0. no fuel expenditure, car slows down, then gradually brake.
Posted 15th Feb 2012 at 14:40
No - a modern car, slowing, in gear, uses zero fuel as the wheels keep the engine turning. Idling however requires fuel. Doesn't matter what revs you're at, engine management shouldn't be pouring fuel into your engine if it's not needed.
Posted 15th Feb 2012 at 14:41
billyboy99
we are driving modern cars now are we?
Posted 15th Feb 2012 at 14:42
I'd be surprised if even the '6 doesn't do it, but yes I have an Astra.
Posted 15th Feb 2012 at 14:44
billyboy99
owain wrote:
I have an Astra.
ooohh you're ard !
Posted 15th Feb 2012 at 14:46
billyboy99 wrote:
owain wrote:
I have an Astra.
ooohh you're ard !
I don't really know what to say to that.
Posted 15th Feb 2012 at 14:47
billyboy99
owain wrote:
billyboy99 wrote:
owain wrote:
I have an Astra.
ooohh you're ard !
then sing it...
Posted 15th Feb 2012 at 14:48
zedx19
Any car with fuel injection I'd say would use less fuel leaving in gear rather putting in neutral and coasting, as previously mentioned, wheels rotating keep the engine running.
Back to the thread, assume you've checked the brake pads? Are you sure extra smoke is actually coming out the exhaust and rear brakes aren't binding?
149bhp ATW stripped GTi-6 & B6 Passat TDi daily drive
HyperGTi-6.co.uk - Videos and PicturesHyper
Posted 15th Feb 2012 at 14:49
On a different note, vacuum pump? Perhaps not pulling the pressure it should when the engine's idling?
Posted 15th Feb 2012 at 14:50
Also, please pay up your membership and post in technical section.
Alternatively, you can GTFO Laugh
Hope this helps!
Posted 15th Feb 2012 at 14:54
Oh yeah, this is General. Do one.
Posted 15th Feb 2012 at 14:55
billyboy99
lol you tarts!
Posted 15th Feb 2012 at 14:58
REPORT
They've done this since about the 80's, that old enough for you?
Leave it in gear ffs.
Posted 15th Feb 2012 at 15:11
yup, even the clockwork jetronic on the 205 does it.
Posted 15th Feb 2012 at 15:14
Plus the extra engine braking it gives you, so puts less load on your brakes, helps prevent lockups etc.
Posted 15th Feb 2012 at 15:18
billyboy99
ok so we have established whats better for fuel economy...brilliant.
we still need to establish why its not braking correctly when in neutral. it does feel like how it did when i was slipping in the snow last weekend, which i believe was ABS kicking in so def related.
Posted 15th Feb 2012 at 15:23
mattgti6phase2
Have you checked the fluid level?? Brake lines also? My old meridian had perished brake lines.
Worth a look i say. Forget about the ABS for now it's a bloody hinderance anyway Big grin
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 15th Feb 2012 at 15:56
billyboy99
thanks for suggestions thus far everyone, will check these over weekend when i am at home with some daylight..!
Posted 15th Feb 2012 at 16:04
btw i didn't report the thread but someone has Doh
Posted 15th Feb 2012 at 16:06
This thread has been locked
