displaying posts 1 to 25 of 36
Author Subject: Diagnosis/Any Ideas?
honestly3k
Hey all,
Some of you may remember when i was thinking of buying a 6 there were a few niggles with the car i was looking at and posted up my concerns.
One of them was that the PAS pump fluid was a milky yogurty consistency. I was satisfied that the reason for this at the time was that some twit had decided that the PAS fluid reservoir was infact the screen wash bottle and dumped some screenwash in the with PAS fluid.
The car was at 60k when i decided i would buy it. Car is now on 101k.
When i first had it serviced at 60k i asked said mechanic to replace the fluid. He said he had to bleed it through about 3 times to get it to run clear.
To be honest i hadnt really looked at the fluid since it was changed at 60k bar one or two times. I noticed that it quickly returned to this milky white/pink yoghurty consistency.
Two weeks ago i was getting a horrible whirring noise when i put my foot on the throttle, getting louder with the more power i was demanding.
Stuwee diagnosed it as the PAS pump so on Saturday just gone, he fitted a replacement for me and bled through the old fluid which was yoghurty! Hmm
Thing is he had to bleed through about 15 Litres of the stuff to get it to run clear. And this was after the fluid appeared to KILL the first replacement pump. We noticed the fluid was clear but very watery in viscocity. Anyway, the first pump he fitted really was whining/screeching and i had no power steering.
Luckily he had another used pump in his supply and fitted that one. I went off for some lunch at this point and he said when i returned that when he fitted the second pump that again it was screeching/whining and the clear fresh PAS fluid went all milky/frothy at first and he again bled it thorough yet another litre of fresh fluid. It was now clear and the pump appeared to be working/i had power steering.
So took it for a quick spin, whirring sound now replaced with induction noise again Love
So took it home after i think my car was p*ssing Stu off by this point (sorry Stu LOL)
Got home 35 miles and it has gone a pinky kind of yazoo consistency (again going yoghurty)
Been out 140miles today and it has remained pinky.
Anyone know if there is anything that can be actively contaminating my PAS fluid?
As if someone had originally put water in it surely it would be mostly gone by now? What is going on?
I bought some new fluid again today and im going to do another change tomorrow i think as it looks to be reverting back to milk again slowly.
Sorry for the essay but the history needed to be explained.
Anyone know whats happening here?
Thanks
Posted 13th Feb 2012 at 17:59
Sounds like you have a small leak in the system which is allowing air to be drawn in. This is what is turning the fluid pink and foamy/milky.
Posted 13th Feb 2012 at 18:19
ryangti6
It sounds very much like either water or some of the contaminated fluid still in there somewhere. The froth could suggest you either have air in the system or are drawing it in somewhere aswell.
If it were me I'd disconnect every pipe and flush it all out that way ensuring every last bit of the old stuff is out and make sure all the pipes are clean, be sure to do the ram too. You can also check all fittings and pipes when doing this to eliminate any other damage being the cause.
Ryan
Posted 13th Feb 2012 at 18:32
yippeekayay
agree...have had loose powersteering pipes before off the rack. Also they are known to leak over time. Advice loosen then tighten all connections that you can get at. Or just get another rack and hoses..got to be cheaper than putting newfluid every 5 minutes.
x box "yippeekayaymofo"
Posted 13th Feb 2012 at 18:33
honestly3k
Thanks so far. I think thats the most plausible explanations so far.
Could anything from the rack liquid wise be getting into the PAS pipes?
Where are the PAS pipes all routed around the car?
I can try do this on Thurs or Fri as im off work.
I really dont know what im looking at when it comes to the rack itself. So wouldnt know where to start tightening bolts etc.
Cry
Posted 13th Feb 2012 at 18:40
Looking underneath the car, you will see the PAS rack. On the rack, you will have two hydraulic unions. See if you can crack these off. If you can you will start to see fluid dripping out. Once this occurs, then tighten them back up. (The engine should be switched off whilst you do this).
Whilst you are under there, check for any signs of red/pink fluid leakage anywhere.
As for any other foreign liquid entering the rack and then contaminating the PAS fluid, this is highly unlikely.
Posted 13th Feb 2012 at 18:48
ryangti6
They are quite easy to follow off the pump and reservoir around the car.
Off the top of my head the one comes off the bottle and goes to the pump (rubber one), the one off the pump goes down under the sump to the rack, and the other ones come back up under the engine mount on the drivers inner wing.
There are only a few connections to check really though and these can be done from the top and the ones on the rack can be reached through the drivers side arch with wheel off or you can just get under the car and do them.
Check the blue sensor in the pipe that goes down the front of the block too, if this has been changed it may not be sealed 100% and could be drawing air.
Ryan
Posted 13th Feb 2012 at 18:51
This a good call. Yes
Forgot about that bit. Doh
Posted 13th Feb 2012 at 18:56
honestly3k
Thanks guys, freaking car is costing me a fortune recently. Bloody b*tch.
When you are talking PAS rack do you just mean the steering rack itself?
Thats above the subframe isnt it? It all seems pretty straight forward but i am useless at even the most simple jobs.
I think it must be drawing air tbh, as its taken too much replacement fluid to be something still lingering. Would air also change the viscocity of the fluid to make it more water like?
The new pump is letting out little groans in tight manouvres today also, something isnt right i dont think Sad
Posted 13th Feb 2012 at 19:12
Yes.
Deffo sounds like you've got some air trapped in there mate, or it is constantly drawing some in from somewhere.
Once you get underneath it to have a look, you will see what we mean. Smile
Posted 13th Feb 2012 at 19:30
honestly3k
stan_306gti6 wrote:
Yes.
Thanks. I really need to get this sorted with minimal cost!
Travelling upto Cambridge on Fri/Sat so will try to get it sorted before then.
Will keep yee updated Unsure
Posted 13th Feb 2012 at 20:22
Stuwee
In respect to drawing air in into the system, i would say it would p*ss out fluid rather than suck air in on the high pressure side ( pipe going from pump to rack or any pressurized pipe on the system).
Even the return pipe from the rack to the reservoir still pumps fluid under pressure although somewhat lower pressure than the rest of the system.
The only place i would say the system could draw in air into the system is the inlet pipe from the reservoir to pas pump because the pump draws the fluid in.
I still think some twat put water into the pas reservoir in the past. When i felt the viscosity of the oil in the reservoir it felt water like compared to nice new fluid.
But i could be wrong.......................
Ph1 Cossack 6
Posted 13th Feb 2012 at 21:39
mattgti6phase2
If you get stuck Chris i don't mind taking a look. Had a long hard think after leaving yours on Saturday and i to agree that there could well be a vacuum being created somewhere.
TBH i wouldn't mind burning your bas**rd car Devil it's just one thing after the other Sad
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 13th Feb 2012 at 21:44
honestly3k
Tell me about it mate. If i could afford another car i would really consider getting shot of it.
The list at the moment stands at
-balljoints
-PAS needs sorting?!
-front discs + pads
Its not like i dont look after it, it just gives me one issue after another. Thumbs down
Was due in with the dent man on Thurs but i think im going to cancel that. Minimum £120 to get the dent sorted and with view to these other bits i just cant afford it.
Its like a woman, a leach on my finances LOL Sad
Posted 13th Feb 2012 at 22:40
honestly3k
I do find it strange that the fluid changed to be like water. It is as if something is getting into the fluid.
But from where? Assuming the rack doesnt have any fluid filled working parts?
Maybe its plumbed itself into the screenwash bottle somehow LOL
I will aim to change the fluid tomorrow after work. But its finding the time when its still light to do so
Then all i can do at the moment is keep an eye on it
Posted 13th Feb 2012 at 22:44
yippeekayay
After thinking about it and Stuwee's comments I would agree with him... the pump creates reasonable pressure that would loose fluid if not tight... so the only part of the process that would let air in would be the pump or the rack and you have done one of them. I wander if there is loads of air in it that hasnt been bled. or the ram in the rack is somehow allowing air in, not fluid out though you say you are refilling it regularly so its going somewhere... give it a good jet wash round the rack, undo the power steering res top up start engine and lock to lock it checking the levels and see if fluids peeing out anywhere.I Had a 205 that did something similar and replaced the pump and cured it...
Posted 13th Feb 2012 at 22:52
honestly3k
It doesn't appear to be losing fluid yipee, it was only bled thru that many times when the replacement pumps were fitted to get the fluid to run clear.
I'm only guna continue to change it because it appears to be becoming milky again.
Posted 13th Feb 2012 at 23:04
Stuwee
Do check the system for leaks still as said, when you left on Saturday the fluid was fine and dandy. By the time you got home it was it as bad as it was before?????
Ph1 Cossack 6
Posted 13th Feb 2012 at 23:09
honestly3k
Not as bad no but it looked to be gettin that way. As of today it looks a deep pink like strawberry yazoo milkshake....i just can't see how something could still be in the system for this long, will change it tomorrow and see what happens
Posted 13th Feb 2012 at 23:13
yippeekayay
hate to say it but this isnt the milk float car is it??? classic symptons, ie: milky yoghurt fluid all over the place...
Posted 13th Feb 2012 at 23:14
Would also be egg like too would it not? Maybe bread crumby too.
Posted 13th Feb 2012 at 23:21
Stuwee
Buy shares in comma and and keep flushing LOL
Had a customer pour engine oil in a coolant expansion tank before, they might have mistaken it pas reservoir for screen wash????
Ph1 Cossack 6
Posted 13th Feb 2012 at 23:26
mattgti6phase2
Laugh my ass off
Wouldn't surprise me in the slightest.
5 x a 306 owner!
Posted 14th Feb 2012 at 00:12
honestly3k
Update, just been out and emptied the old and in with the new fluid.
Heres the fluid just before i dumped it out. This fluid has done about 340miles.
Fresh stuff, engine not started yet
Engine started, left to idle
Video of engine starting, and left to idle. Did go a bit frothy and then started looking a bit yazoo like again.
Say if this link doesnt work?
I did check briefly all the pipes in view and the blue connector. No signs of any disturbances. Blue connector tight. It all looks dry and dusty down there.
There was a load of old white yoghurt under the filler cap/reservoir neck so i cleared that out with a cloth but some dropped into the reservoir.
At this stage im more inclined to believe there is just major contamination in there and its going to take a LONG time and a LOT of PAS fluid changes to get it back to normal.
I might even try to bleed the whole system from the lowest point this weekend if i get the chance
Posted 14th Feb 2012 at 16:20
ryangti6
You need to do what I said then by the seems and totally flush the system step by step.
I'd guess you are leaving some contaminated fluid in the circuit somewhere, how are you flushing it?
Ryan
Posted 14th Feb 2012 at 16:43
