Gti6 pistons fitted to 8vt (152mm) rods, pistons now sit approx 6mm below deck, the thinnest head gasket i can
find (1.2mm), slight skim, this lot gives 7.1:1 CR if my calculations are correct.
i was doing a bit of random browsing and discovered that the road spec 205 T16 ran a 6.5:1 CR, some Zetec turbo
guys are using sub 8:1 CR's.
i know off boost driveability will be rubbish, but then it is a turbo'd engine. Looking for around 250 ish bhp with
T3 0.48 / 0.42 turbo and cosworth weber marelli/pectel management plus 803 greens
Any thoughts?
ps, whats the best method of pushing pins out of pistons / con rods? tried gentle heat and light pressure on
15 tonne press but they dont want to budge
JWP EFi
