displaying posts 1 to 25 of 28
Author Subject: 23mm torsion bars
peugeot96
Hello
Have anyone tried 23mm torsion bars for road use? Will they be to stiff?
Running 21mm now, and i dont think they are stiff enough.
Does anyone make 22mm?
Posted 2nd Feb 2012 at 07:01
I think you can get 21.5s from a partner van or something?
Posted 21st Feb 2012 at 18:51
I believe the Partner vans use 21mm, if I remember correctly. Yes
I am currently running 21mm, and they seem fine to me. I also have a 30mm anti-roll bar, solid beam mounts, KW dampers and lowered 40mm from standard. Tyres are R888's, and the back-end seems planted.
What other mods have you had done to the rear beam?
Posted 21st Feb 2012 at 18:55
clen666
Think partner bars are 21.3 but they aren't wide enough for 306 beams, they use them on 205s I think
Team 'unintentional rat look'
Posted 21st Feb 2012 at 18:59
Actually I think your right Smile
Posted 21st Feb 2012 at 19:37
allanallen
Partner bars are 309/405 length Wink
Facebook
Posted 21st Feb 2012 at 22:01
rallyeash
23mm on my 205, although its mainly a track car don't find it a problem when road driving
309 3dr K20 Type R
Posted 21st Feb 2012 at 22:26
simonjames
21mm is the largest you can get from factory fit that will fit our beams but i'm sure you can get bigger custom made
MY EBAY ITEMS
07943066306
Posted 21st Feb 2012 at 22:28
I have 23mm on my ZX, works great with 180 lb front springs Big grin
Posted 22nd Feb 2012 at 00:32
jord294
Any joy in finding another shell?
There's a breakers near me with a complete Ming blue sort of colour volcane
Posted 22nd Feb 2012 at 00:56
simonjames
they not a factory item though are they ?
MY EBAY ITEMS
07943066306
Posted 22nd Feb 2012 at 08:11
nope, only cost £200 though.
Posted 22nd Feb 2012 at 09:47
Whats wrong with the shell then? Rust?
Posted 22nd Feb 2012 at 09:50
simonjames
Not too bad really when you think 10-15 year old xsara bars sell for £80-120
MY EBAY ITEMS
07943066306
Posted 22nd Feb 2012 at 10:04
big dent.
Posted 22nd Feb 2012 at 10:43
Damn.... Crash?
Pug1off do 22mm bars btw
Posted 22nd Feb 2012 at 22:44
atterz
Lol @ big dent. You could say that!
owain wrote:
Posted 23rd Feb 2012 at 00:10
pete_rallye
I found 23.5mm bars miles too stiff for road use, back end used to take off over spee bumps, and back end traction over bumpy roads was a bit arse twitchery. On fast smooth roads (aka race tracks) they were brilliant, but I wouldn't use them for road use, stick to 21mm.
Lap of the 'ring
Posted 23rd Feb 2012 at 00:54
which dampers did you use Pete?
Posted 23rd Feb 2012 at 11:45
pete_rallye
That was with standard KW V2's, probably massively under damped. I have the same on my BTCC 306 and on the odd occasion I 'test' it up and down my road the back end still takes of over speed bumps, and thats with perfectly balanced Penske shocks...
Lap of the 'ring
Posted 23rd Feb 2012 at 21:26
I use KW V2's on 21mm bars, excellent fast road setup IMO. Yes
Posted 23rd Feb 2012 at 21:27
peugeot96
Im running on solid rear mounts and the car is fitted with Supersport coilovers. 21mm tbs and 24mm arb. Will soon fit Bilstein b6 and hybrid arb. Maybe that will help?
Posted 25th Feb 2012 at 13:35
In my opinion the 30mm ARB does make a massive difference to the rear-end. Yes
It really compliments the rest of the mods to the rear beam I have found. If you fit the hybrid ARB you will see a positive difference, but personally I would go for the 30mm. Smile
Posted 25th Feb 2012 at 17:24
eddy_gti6
Is there much difference with the 21mm bars over the standard 19mm gti6 bars? I have a spare beam here I am thinking of rebuilding with bigger torsion bars and solid mounts along with my koni shocks. Will mainey be for road use with the occassional track day. What do you all recomend?
Posted 25th Feb 2012 at 18:54
Eddy - The standard bars are 20mm not 19mm. Yes
The difference every 1mm makes on size is roughly 25% stiffer, so yes, there is quite a large difference. Thumbs up
Posted 25th Feb 2012 at 18:58
